ZZ-8200/hk-828 voice recorder chip/ DIY LOOPER/SAMPLER
Started by smccusker, December 17, 2005, 07:14:51 AM
smccusker
datasheet
Has anyone looked into using this chip in a diy looper capacity?
they're pretty expensive at 20 bucks a pop from Jaycar, but they have have alot of features built into the chip, greatly minimising the parts count per circuit.
I'll admit I don't really know very much about this sort of thing, but from the looks of the data sheet, it seems like it might be well worth a look into.
any ideas?
Guitar -> Amp
smccusker
one of the most interesting features about this is that you could record a number of different short loops, and then rig up some sort of control switching to select which loop is played.
Guitar -> Amp
smccusker
here's a link to the corresponding article that appeared in silllicon chip magazine.
Guitar -> Amp
no one ever
its too bad there's no consumer demand for voice recorder chips that play backwards....  :icon_mrgreen:
(chk chk chk)
smccusker
Quote from: no one ever on December 18, 2005, 01:26:04 AM
anyone have schems for a time machine?
Guitar -> Amp
Processaurus
It won't work out well for a looper, because in the datasheet it says it inserts a 1.5 second silent period before returning to the beginning of the sample, while in looping mode.  This is so you know that its the end of the sample.  Bummer.  What I do like is that the playback/record pitch is variable about an octave, by a variable resistor.  This also scales the anti-aliasing filter's cutoff frequency at the same time. Nice.
puretube
smccusker
Quote from: Processaurus on December 19, 2005, 02:00:07 AM
that's a feature i unfortunately excitedly overlooked :(
care to elucidate puretube?  :icon_biggrin:
Guitar -> Amp
puretube
write/read alternatively, such that the "gap" in one will be filled by the other, & vice versa...
The Tone God
Quote from: puretube on December 19, 2005, 05:47:40 AM
Sounds like a painful endevour for little gain.
Just my opinion.
Andrew
A.S.P.
Analogue Signal Processing
The Tone God
smccusker
Quote from: The Tone God on December 19, 2005, 02:22:12 PM
Just my opinion.
Andrew
i was thinking the same thing :(
Guitar -> Amp
