new thing modulator vero layout
Started by smccusker, December 23, 2005, 02:40:46 AM
smccusker
I had a crack at doing a vero layout for this simple circuit. this is the first time i've done a vero layout and i tried to keep it as tight as possible, though i still think it could be tighter. all comments welcome as always.
oh, the original schem is here
Guitar -> Amp
MartyMart
That's great ! :D
Just cut off the "spare" trace top 'n bottom .... ~:D
MM.
RLBJR65
#2
Thanks, looks good. The more you do the easier it gets. It's small enough, other than cutting off the top and bottom strips like Marty said, I don't really see where you could save much space. 8 strips and 12 holes is only around 3/4" X 1 1/4" with the vero board I use.
You could eliminate that jumper on pin 2 just put the output cap in its place move the output up one strip. No need to cut the trace at pin 8 then either.
It would not help with this layout but if you use a socket for the IC you can run jumpers like this layouts pin 7 to ground connection, under the socket. Just something to keep in mind for future layouts.
Great job!
Richard
Richard Boop
MartyMart
Yes, jumpering 'under" the opamp socket is a nice trick and sometimes can save
you 2/3 "holes"  :D
Merry, Merry .....  MM.
smccusker
Quote from: RLBJR65 on December 23, 2005, 07:10:06 AM
ah, good idea. my spacial thinking is a bit rusty  :icon_confused:
thanks for the comments guys.
Guitar -> Amp
syndromet
#5
It's a great little layout, but everything is wieved from the non-copper side. Just to let you know...
My diy-site: www.syndromet.com
