Big Muff Pi- review/questions
Started by tennisdude, January 07, 2006, 09:42:46 PM
tennisdude
thanks peter. the stupid resistor mistake was on my part, i substituted an 8.2k resistor for an 82k resistor, which happened to be in series with the sustain pot (which explains that problem).
it sounds great now, goes way over unity gain if i want it to, and distorts like crazy :icon_mrgreen:
john
pyrop
Good to see you got it going allright.
Nothing more annoying than putting a project together and it dont work.
Good Luck on your next project
pyrop ;D
  That misvalued resistor [82k for 8k2] would be similar to turning the sustain pot down some, but would not account for the misbiased transistors.
tennisdude
are the transistors going to pose any sort of threat? the pedal sounds fantastic now, the sustain pot and tone pot work like a charm now, and i can get that "buzzsaw" sound if i want to :D
i think the mis-biased transistors might have been a product of some poor soldering. i spent a while last night just cleaning up the soldering and that probably did the trick.
If the transistors are still screwed up, they sound pretty damn good  ;D
John
  Bias is relatively easy to check. It is a routine I use for determining if transistors are within thier operational bias voltage range.
