ah, crap
Started by superjoe, January 14, 2006, 01:09:25 AM
superjoe
ok...im on my last few things to solder but i cant figure out 100% which is the tip, ring, and sleeve on the dragonfly layouts....haha, im really bad at this stuff, i promise ill stop the questions after this thing gets done.
superjoe
junkyjunky
im new to this but i think it goes from left to right on dragon's layout on the input jack as follows: tip, ring, and sleeve.
trash is often friendly
Connoisseur of Distortion
if you post a link they will answer  ;)
junkyjunky
hopefully that isnt a snide remark because i wouldn't post if i didnt believe it to be correct.  ;D
d95err
Just check how the battery and volume pot are connected in relation to the jacks. The tip of both jacks will go to the footswitch. The negative battery pole (unless it's positive ground) will go to the ring of the input jack. The sleeve of both jacks will go to ground, so it should be easy to identify.
fixr1984
Ring is the green wire
sleeve is the red wire
tip is the pink wire or purple on the output jack
The Tone God
A trip to the DIY FAQ could help. You shouldn't have to ask for a link as I'm sure you know its on the top of this page. ;)
Andrew
P.S. Please use better thread titles. I thought this topic was about crap. I was going to mention something about Lopez.
