AMZ Mosfet Question
Started by seanthomas46, January 17, 2006, 06:45:31 AM
seanthomas46
What kind of switch is this?  It labels it as bypass, but has three extra terminals than a normal DPDT labeled Switch 1 ???
  Can anyone explain to me what this is?
http://generalguitargadgets.com/diagrams/ge_boost_lo_amz_mosfet.gif
My Second question is that for this project there is an option for more control.  It labels these two options as OUT 1 & OUT 2.  Does this mean that there are two out jacks?  What do the two OUT's represent physically or practically?
http://www.muzique.com/schem/mosfet.htm(second schematic at bottom)
  It also calls for the first option out 1, to switch the original 5K linear pot with a 5K linear pot with a mounted SPST switch which is opened when the pot is dialed at minimum setting :icon_question:  Do these switch mounted pots come stock?
  You can also use a DPDT switch two swith between the two options.  I've drawn the addition onto the revised schematic, have I got it correct?
Forget, I can't figure out how to use this f*n insert picture crap.
Sean
davebungo
Quote from: seanthomas46 on January 17, 2006, 06:45:31 AM
I think it's a 3 pole double throw - could be a bit expensive, not sure.  You could probably manage without this by using RG's bypass method - see Millennium bypass
You could connect these two outputs to a differential input of some other device (for example the balanced input of a mixer) but for guitar stuff I would just connect Output 1 and ignore Output 2.  Output 2 is just a phase inverted version of Output 1 i.e. As Output 1 goes up, Output 2 goes down and vice versa.  Note that this only works when the source bypass capacitor and resistor is switched out.  Once you engage it, Output 2 will drop in amplitude although it will remain inverted.  With R6 at minimum, you will see virtually no signal on Output 2.
I would have thought you would be able to get them somewhere - not sure.
seanthomas46
thanks Man.
So I've done some research and can't find the switch type anywhere.  I've also learned a bit on the Millenium Bypass.
  I would like to do the two option thing, because I always like more dials and a good learning curve.  But not worth the rare parts acquisiton and all the other confusion for a boost, I'll save that for my swell fuzz!
thanks
spudulike
First point is that the Mosfet boost does NOT use rare or hard-to-get parts. The switch is a 3pdt and Aron sells them. He also sells the BS170 you need, and a bunch of other stuff. The url is
http://www.diystompboxes.com/cart/
They are excellently priced, excellent quality, fully tested and helps him run the forum  :icon_lol:
Get the switches, tranny, stripboard etc from Aron and build it. I built mine using a pcb (but the same schematic as below) and its a fantastic booster.
The buffered bypass is also very handy  :icon_wink:
Next you need the Trochy layout and schem over at Wampcat (Brian's) site :-
and also this
