Pages: [1]
Author
Topic: NPN Booster completed ...& pics!!! (Read 4733 times)
aron
Administrator
Aron Nelson
It looks GREAT!
Logged
siaoguitar
Thank You Aron! Still thinking of putting the circuits in different enclosures like mint tins....etc...It's so fun man!! Aron, i got a strange problem with this npn, when i max the vol, and turn the gain 3/4 way up, i get a continuous who....wee... sound.
And sometimes with both vol & gain maxed, i get TREMOLO effect, whatz up with that?
Need some advice..Aron
« Last Edit: January 18, 2006, 11:10:27 PM by siaoguitar »
Logged
aron
Administrator
Aron Nelson
I have never heard of this happening, but I would guess it's oscillation. Try and keep the signal wires very short and if necessary, shield the input and ouput (ground only one side of the shield).
Logged
siaoguitar
Hi Aron, you mean ground either input or output jack is it ?
Logged
aron
Administrator
Aron Nelson
I'm sorry. What I meant was use shielded cable for the input and output wires from the circuit board to the switch and from the switch to the jacks. Only ground one side of the shield (board side for wire going to switch, jack side for wire going from jack to switch) and see if it helps.
Logged
windwaker
Hate to be such a noob, but eh, what schematic did you use? The only NPN boost schematic I've found has only one pot.
Logged
siaoguitar
Hate to be such a noob, but eh, what schematic did you use? The only NPN boost schematic I've found has only one pot.  The usual one man, did you see the 100k pot for volume? that's the one!!!
Logged
siaoguitar
I guessed so......variable - adjustable.....
Logged
windwaker
Your pedal has two potentionmeters, one for volume and one for gain. This one only has one potentionmeter. Where did you use an extra one?
Logged
siaoguitar
Your pedal has two potentionmeters, one for volume and one for gain. This one only has one potentionmeter. Where did you use an extra one?  That's the 100k pot for volume.
Logged
aron
Administrator
Aron Nelson
He must have wired the 100K as a volume pot. 10uF to outside lug, wiper to output jack, other outside lug to ground. Reverse outside lugs if backwards.
Logged
woulfer
Thanks for the explaination, Aron. That makes sense.
Nice job, by the way, siaoguitar.
Logged
alvintang
sorry for being a noob..but i still dont get it. can anyone who has added the volume pot post some pics on how u do it? thks heaps!
Logged
KORGULL
I'll elaborate on Aron's description to hopefully make it clearer: aron wrote: He must have wired the 100K as a volume pot. 10uF to outside lug, wiper to output jack, other outside lug to ground. Reverse outside lugs if backwards. You see the 100K resistor that is between the 10uF cap and the output? Replace it with a 100K potentiometer (preferably audio taper, but linear is okay too). Break the connection between the 10uF cap and the output jack. Connect one of the pot's outside lugs to the 10uF cap. Connect the other outside lug to ground. Connect the middle lug (also called 'wiper') to the output jack's tip lug. If the volume works backwards - so the level gets lower when you turn it up - that means the two outside lugs need to have their connections swapped. Here is more info on wiring pots that may help you get the connections right the first time: http://www.diystompboxes.com/cnews/FAQ.htmlLug 1 is the one that usually connects to ground. Hope that helps.
« Last Edit: July 07, 2006, 04:18:12 PM by KORGULL »
Logged
alvintang
thks for the help mate, really appreciate it
Logged
Pages: [1]
