solderless connects/disconnects ==> recommendations?
Started by gaussmarkov, January 29, 2006, 11:35:39 AM
gaussmarkov
i'm wondering about a good solderless connection method that would work well inside a stompbox.  for example, suppose i don't want to solder my wires to the pcb. instead, i solder some kind of terminal on the pcb and a connector onto the wire so that i can disconnect easily.  does anyone have some recommendations among the many possibilities on mouser or similar?  (wherever this has been discussed, i missed it.  maybe because there are so many "solderless" breadboard threads. :icon_wink:)  thanks!
AdamB
I suppose you could use ribbon/interface cable? Use one of the male connectors on the PCB, with each pin being a different input/output to the board. Then plug in the female ribbon cable, and strip the wires so there all seperate, cut each to length and solder to where-ever they go.
-Adam
[indifferent::engine]
http://www.indifferentengine.com
twabelljr
Shine On !!!
