17,5V in 18V E-H effects?
Started by Steben, February 17, 2006, 10:23:15 AM
Steben
Still haven't got any answers, so I'm bumping again...
Will 18V fx work consistently on 17,5V (charge-pumped)?
I know the voltage is brought down to 15V inside an Electric Mistress, but is it sensitive to not-exactly-18V?
I just want to make sure!
Peter Snowberg
A charge pump will probably not supply anywhere near the required current.
Eschew paradigm obfuscation
nelson
There is the LT1054 charge pump that has up to 100ma.
Do a search.
My project site
Winner of Mar 2009 FX-X
d95err
Such a small variation (about 5%) will probably make no practical difference whatsoever. Can't say for certain, since I'm not sure what circuit you are talking about.
nelson
If you get a regulator that can work at 2.5v over regulated voltage it should be fine.
My project site
I'm not saying this is the case for the EM, but in some instances, the 18v or 2-battery arrangement is not to necessarily supply 18v to the chips themselves, but to supply enough voltage to some on-board regulator or regulation circuit that, in turn, supplies a stable 12v to the chips.  Keep in mind that most BBDs don't really take kindly to supply voltages over 15vdc.
Steben
#6
Quote from: Peter Snowberg on February 17, 2006, 10:44:53 AM
A MAX1044 supllies 200mA, no? I that still not enough for an analog pedal?.....
EDIT: was wrong here... >:(
Still: scott schwarz powers his PT80 (at least 35mA) with a proclaimed 10mA charge pump!
Anyone knows the current consumption of an electric mistress?
MAX660(100mA) works only on max. 6V >:(
Steben
Quote from: Mark Hammer on February 17, 2006, 03:15:35 PM
As I thought, thanks. Still there is the current problem... ::)
Peter Snowberg
OK, maybe current isn't a problem. ;)
Clean current... that may be another issue. I've never been too big a fan of charge pumps for power supplies. I would go the direction of a switching boost regulator.
If there is a 15V linear regulator powered by that pump, a 15V boost regulator gets you there in a single step with greatly increased efficiency. Just substitute one for the other.
http://www.linear.com is my favorite linear IC maker. :)
Assuming the current is available, it should work fine on 17.5V.
Steben
Quote from: nelson on February 17, 2006, 11:34:32 AM
Do a search.
Thanks.
Searched, checked and ... ordered samples from TI! I luv their sample program... they should be proud of it.
