Draining caps
Started by Joecool85, February 19, 2006, 12:26:10 PM
Joecool85
Ok, well, I was working on a stereo today and had to drain some caps, the biggest were 2200uF, I just shorted them with a screwdriver.  I know thats the ghetto way, so I want to know, how do you guys do it?  This is for solidstate btw, not tube.
Life is what you make it.
https://www.ssguitar.com
Herr Masel
I think the proper way is similar, but with a wire that has the other lead clipped to ground with an alligator snap. Wouldn't it be pretty dangerous with just a screwdriver, as in sparks flying etc.?
Joecool85
Yeah, it sparks quite a bit, and leaves scorch marks on the PCB.  You are suppose to use a resistor.  The thing is, the only things I've seen recommend 25k resistors, but that is for tube amps that deal with like 400-500volts, not solidstate amps dealing with like...50volts or so.  So I've heard using as small as a 2.7ohm resistor.  I was thinking something like this: http://www.radioshack.com/product/index.jsp?productId=2062292&cp=&kw=resistor&parentPage=search
bancika
IIRC any resistor will work, just larger one will drain it faster and you could see sparks
no one ever
Quote from: Joecool85 on February 19, 2006, 12:43:13 PM
kinda hard to find a 25k 5-10w resistor
(chk chk chk)
bancika
not really, I found 100K 5W with no problem
A small appliance bulb (like the ones inside your refrigerator) will be content to have 120v pass through it, and will drain the caps nicely.  If there is a lot of current stored, your bulb will light up briefly, but pass the current to ground safely.  Happily, it doesn't matter what side of the filament connects to ground.
Joecool85
Thats a pretty good idea with a lightbulb...
no one ever
(chk chk chk)
gulliver
Quote from: Joecool85 on February 19, 2006, 05:43:05 PM
I wonder if a lightbulb went off in his head when he though of it?  :icon_idea:
After wards he was quite drained  ::)
Joecool85
Wow...that reminded me of my dad.
bancika
Some electrolytics do not survive the short-with-a-screwdriver draining. The stored charge changing so fast actually distorts the internal plates mechanically and can short them out. If they short during a drain, they weld, and good-bye cap.
A resistor across them, any resistor will drain them. How fast? Hmmm... let's see.  The time constant of any R-C is just R*C, in seconds. In one time constant, the cap will drop to 0.632 times (1-1/e) its original voltage. In two time constants, it drops to 0.632*0.632 = 0.399 of the original. At three time constants, you get 0.252... and t five time constants, 0.10008, which most people take to be discharged.
So if you have a 100K (for instance) and a 2200uF cap, the time constant is t= 1E+5*2.2e-3 = 2.2e+2, or 220 seconds, and a 100K will drain a 2200uF cap to 1/10 of its original voltage in 1100 seconds, or 18.3 minutes. Too slow. A 10K will drain it in 110 seconds, and a 1K will drain it in 11 seconds. The 1K sounds like the right thing here.
What current flows in a 1K? Depends on the voltage. I'm guessing if the amp has main caps of 2200uF, it's a 30W or less amp, and the voltage is perhaps 25V. So the 1K pulls 25ma initially.
Good practice in power supplies is to put a resistor across all power caps that pull the capacitor down in under a minute or so. So if you have a 2200uF cap and want to drain it in one minute, that is roughly equivalent to saying "I want a bleeder resistor that makes a time constant that's 1/5 of 60 seconds, or 12 seconds."
The resistor is then 12sec/2.2E-3F = (12/2.2)*1E+3 = 5454ohms. A 5.1K will do that nicely.
If we leave a 5.1K resistor across the cap all the time, what power does it dissipate? P = V^2/R or (25V)^2/5100 = 0.122W, or about 1/8 watt. A 1/4W resistor will work fine there.
So you could put a 5.1K resistor across a 2200uF cap all the time. It would eat 1/8W, and would discharge the cap to 2.5V in one minute.
Joecool85
Yeah, I guess the power supply on the chipamp I'm building does that so you don't have to worry about it.  Just shut it off, unplug and wait a couple minutes and its drained...I like that.  Thanks for all the help guys.  I *probably* won't drain any more caps by shorting them.  Although you do get one heck of a spark!
Dave_B
Quote from: Mark Hammer on February 19, 2006, 05:21:11 PM
I had a similar tip when repairing a fuse-blowing Onkyo reciever.  Wiring a light bulb across the fuse socket allowed me to fix it without going through a box of fuses.  If the bulb lit up when I hit the power switch, I hadn't found the problem yet.
Now if I could figure out how to get around a speaker protection circuit, I could fix my old Yamaha...
Help build our Wiki!
Xlrator
I have light bulbs with wires soldered onto them. Drain caps on all kinds of stuff that way. It will also give you a visual when it is drained.
Listen to cKy!
