Simple switching-why can't I figure this out?!
Started by Noplasticrobots, February 21, 2006, 01:33:48 PM
Noplasticrobots
Ok, I don't know why I can't figure this out! I want to install a switch on a Bazz Fuss that selects between two different diodes. What type of switch do I use? I tried a SPDT with the common terminal (center) wired to the collector of the tranny. Then I connected the negative side of both diodes to the base and the other ends wired to the open switch positions. It didn't seem to work.
On a similar and even simpler switch wiring question: how do I wire a switch at the output to select between two different capacitors?
Thanks for all your help!
I love the smell of solder in the morning.
ezanker
I'm not sure what your diode switching problem is as your description sounds correct...
For caps I like to use the fact that capacitance adds up when caps are put in parallel.  Therefore you can put 2 caps in parallel and use an SPST switch to break the connection of one of them.
                        SPST
        ------CAP2---   --
        ------CAP1-------
aron
Maybe it's working. Diode changes can be subtle.
Noplasticrobots
I just realized-I might have an on/off SPDT slide switch (it's unlabeled); I need an on/on SPDT don't I? d'oh!!
