Happiness Is...
Started by LyleCaldwell, February 24, 2006, 12:42:15 AM
LyleCaldwell
Drilling out 13 boxes and not making any mistakes!
Much better than the box I drilled yesterday, only to have some holes mysteriously offset.  Turned out my drill press was loose on the post - tightened those screws up.  Fixed the offset holes with Bondo (I love Bondo).
But I'm glad I didn't have to Bondo 13 boxes:
What does this button do?
psionicaudio.com
burnt fingers
Man I wich I had a drill press.  I have yet to perfectly dirll a box.
Rock and Roll does not take a vacation!!
www.rockguitarlife.com
My Music
jonathan perez
seriously...i have to do it all super meticulously...
Doug_H
Looks nice.  :icon_wink:
I don't know where I'd be without my drill press...
BDuguay
Remember when we used to say that about the internet :icon_wink:
B.
Processaurus
Lyle, thats pro that you drilled little holes for the locator tabs on the pots to index them.  You probably know this but a drawback is that you can see the holes if your knob choice is small, or if the knob sits up high.  I tried this recently and ended up putting a round sticker around the pot shaft to cover up the hole in an un-obvious way, it actually worked out well because the sticker could also act as a graphic with knob setting marks.
Are the 17 going to all be the same design? to sell? to use?  17 big muffs in series?
goosonique
Quote from: Processaurus on February 24, 2006, 07:59:07 PM
Yup those holes let moisture in ....very bad.
Try to avoid if possible.
<((one man with courage makes a majority))>
LyleCaldwell
I'm using the Davies knobs like Fulltone/Keeley, so the locator holes won't be visible.  These are a limited edition reissue of the Guyatone Zoom pedal from the early 80s.  All 13 are already sold to various U2 freaks.  It's a simple but good sounding pedal that Edge used on the first few albums.  Very rare these days, and going for over $300 when you find one.
I'll post more on this project soon - I'm halfway done wiring the circuit boards, and half the enclosures have the primer and color coats on them.  It started to rain so I couldn't finish painting everything today.
psionicaudio.com
LyleCaldwell
Quote from: goosonique on February 24, 2006, 10:27:03 PMYup those holes let moisture in ....very bad.
So does an empty expression jack or unused stereo jack.  I'm not too concerned - the RC Booster has the same locator holes.
As a player, I'm much more concerned with jacks and pots staying tight than I am with whether a pedal is waterproof.  But then again, I can hold my drink.
psionicaudio.com
LyleCaldwell
OK, here's one (of the thirteen) populated PCBs with pots attached:
And here's a functional test pedal next to a painted enclosure awaiting clearcoating:
psionicaudio.com
Peter Snowberg
NICE! 8)
That's a great looking board.... metal fim all over the place. :)
I don't see many polystyrene caps in effects. Very cool.
Eschew paradigm obfuscation
LyleCaldwell
Thanks!  As to the polystyrenes, I just searched Mouser for the values I needed, and the choice was limited.  The polystyrenes were the only options in the values I needed that would fit in the available space.  They are very pretty, though.
psionicaudio.com
343 Salty Beans
you're full of crap, that enclosure ain't painted  :D
no, seriously, how'd you get that done?
LyleCaldwell
psionicaudio.com
343 Salty Beans
well, it turned out really freaking nice. I bet the U2 addicts (myself included) will love that.
LyleCaldwell
The schematic is at http://filters.muziq.be/model/vox/vshaped/1901 if you want to make one for yourself.  Sounds nice!
psionicaudio.com
