|AMPAGE| |GEOFEX| |AMZ|
May 20, 2013, 02:57:30 PM
890935 Posts in 97567 Topics by 28670 Members
Latest Member: Sonicdeath
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  Wylde OD and MPSA14 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: [1] Go Down Print
Author Topic: Wylde OD and MPSA14  (Read 517 times)
Xavier
Xavier M.
Wylde OD and MPSA14
« on: February 24, 2006, 02:37:37 AM »
I don't have any of these Darlingtons, so after some research I used a 2n5308, which seems to be a suitable replacement , though I had to twist the collector and base pins, according to the datasheet.
Thing is, it doesn't sound. I've used an audio probe and signal stops as soon as it hits the transistor. I even have de-twisted the pins but still nothing.
So, my problem is clear I think.........is there any other choice? can I use 2 transistors in a darlington configuration as a sub?
Logged
Marcos - Munky
Marcos Paulo Baliscei - Brazil
Re: Wylde OD and MPSA14
« Reply #1 on: February 24, 2006, 05:41:48 AM »
Try a high gain transistor. I built mine with a BC549C and it works fine.
Logged
Xavier
Xavier M.
« Reply #2 on: February 24, 2006, 05:58:38 AM »
I'll try then , but the gain range of the Darlingtons is way different from any FET, right? isn't that important?
Logged
MartyMart
Martin L / Berlin for a while
WWW
« Reply #3 on: February 24, 2006, 06:34:35 AM »
That's right, the gain is well above 1500 hfe .. !
I used a much more common MPSA13 and it worked a treat Cheesy
MM
Logged
tungngruv
Tony B
« Reply #4 on: February 24, 2006, 09:41:06 AM »
I made one using two 2n5089 wired as a Darlington. It worked fine and sounded great.
Logged
Marcos - Munky
« Reply #5 on: February 24, 2006, 02:09:53 PM »
I believe it woudn't make a big difference, since the transistor are for a buffer. Give a try with a single high hfe transistor and with a homemade darlington.
Logged
burnt fingers
ScottF
WWW
« Reply #6 on: February 24, 2006, 02:52:04 PM »
Does somebody have the schematic for this?  I would love to see it.
Scott
Logged
Rock and Roll does not take a vacation!!
www.rockguitarlife.com
My Music
Marcos - Munky
« Reply #7 on: February 25, 2006, 06:42:36 AM »
http://server3.uploadit.org/files/Torchy-Wylde_Schematic.jpg
Logged
Pages: [1] Go Up Print
« previous next »
Jump to:
