Torchy's AMZ Mini-Booster Layout. What's "A" and "B"?
Started by vanessa, February 27, 2006, 02:34:26 PM
vanessa
Looks like to wires off the board one marked A and the other marked B. Do this go to a switch? If so what does it do?
RDV
troubledtom
RDV
They may also be points where you could switch that cap(C6) in & out of the circuit for a switchable boost/cut.
RDV
Lurco
RDV
vanessa
I do remember someone talking about a switch mod. I can't find it when I do a search...
:icon_cry:
RDV
Quote from: vanessa on February 27, 2006, 05:02:18 PM
:icon_cry:
All you'd be doing is using a switch to make or break contact between A & B either leaving in or shorting C6, it's just a moregain/lessgain mod. Just build it and take a wire from each point and stick them together and pull them apart and see what you think.
RDV
vanessa
Yes it's a gain switch. Jack talks about it here:
http://www.elixant.com/~stompbox/smfforum/index.php?topic=39725.0
I'll have to check that out.
Thank you everyone!
:icon_smile:
troubledtom
Quote from: troubledtom on February 27, 2006, 04:37:20 PM
nothing, test points :icon_twisted:
         -tom
jack told me they were test points , but you can do what he posted and lower the gain.  i for one whould likely never
use that mod.
          but , if it works for you , rock on!
                               - TOM    :icon_mrgreen: :icon_razz: :icon_smile: :icon_wink:
bean
I built it with the switch. It's most noticable when stacking different effects or boosters. Nice option, but not really a whole lot of difference between them.
vanessa
Quote from: bean on February 27, 2006, 10:22:58 PM
Jack PM'd me and said, that they were test points or places for possible mods. One that he suggested is:
"you could use a small capacitor C6 across the source resistor and then use the A/B pads to switch in a larger value...  this would give you an option of treble boost or full range."
That sounds pretty cool.
