i've destroyed gcb?
Started by Loggie, March 02, 2006, 01:56:26 PM
Loggie
I do this weldings  in 3pdt switch but the pedal (gcb 95) but it does not work.
I've removed a buffer. ples someone can paint me a layout? http://www.stinkfoot.se/andreas/diy/mods/images/dunlop/led3.JPG
there are blue layer
purple
green
another 4 layers... where they start?
Loggie
Loggie
Paul Marossy
Are you sure that your switch is wired correctly? If it were rotated 90 degrees, it won't work...
Loggie
Also Wik
Well arent layouts menat to be looked at as if the lugs were going horizontally? So it's possible you misinterpreted the layout and wired it 90 degrees off like Paul said.
Loggie
Quote from: Also Wik on March 02, 2006, 03:26:33 PM
yes
I wire it 90 degrees?
Loggie
He work if the wha is on.
in off is don't work the signal don't arrive in amp
Loggie
I've wired but nada... :'(
nobody can paint his connections? with 3pdt?
Loggie
please heeeeeeeeeeeeeeeeeeeeeeelpppppppppp
  Look through the eyelets is how I find 'north' on a 3PDT, real easy to wire is with 'west or 'east as 'north', because they're not marked in anyway I know except the eyelet holes....yo can look through those and see north IIRC...depends on the exact switch maybe i imagine...DMM tells the tale of course.
twabelljr
#11
    Do you have the small white jumper that connects the bottom left terminal that has the green wire hooked to it to the far right terminal in the middle row next to the white wire? If it does not work in bypass, it seems like it may be missing.
        0  0  0
        0  0  X     ---Hook X to X
        X  0  0
In the picture in the link you posted, it hooks the 2 X's together.
Shine On !!!
Loggie
I've used the switch as a dpdt and I've ignored a line of pin.
now the wha work and is true bypass
Paul Marossy
Quotenow the wha work and is true bypass
Cool!  :icon_cool:
