soldering iron advice.
Started by mercyfulfate, March 28, 2006, 06:52:00 PM
mercyfulfate
i have an old radio shack iron and im wanting to upgrade.
im looking at the weller 25 watt iron with a few accessories. it has the fine point tip as well as a few others.
the radio shack iron is a switchable 15-30 watt iron. it does pretty good on the 30 watt setting but the weller im looking at is a 25 watt.
i mainly do effects pedals and the like.
would the weller 25 watt be as good as the radio shack 30 watt i have? and is a 40 watt too much?
thank you.
mercyfulfate
twabelljr
    CAUTION: This is just MY opinion.
Depending on your budget, if you can afford a station with temperature adjustment controls (digital or analog), go with that.
Next, there are irons where the temperature is controlled by the tip. I would recommend this as your next choice. A 600 deg. F. tip would be a good start.
Lastly, any decent 25-35 watt iron with interchangable tips will do just fine.
The key is to shop around online. You can find some good sales most of the time. Just do a search for blah blah soldering iron and go from there. Also, do a search for soldering iron here at this forum. There has been alot of good advice given on this subject in the past. Have fun shopping, TWA.
Shine On !!!
gulliver
25watts seems low. I have a Radio Shack 20/40, and the 20 isn't hot enough for modding pedals; at least with my tip and way of soldering.
$uperpuma
Alex C
This topic has been thoroughly covered in many threads (I don't mean to sound harsh, just letting you know there is a lot of info available  :)  ).   The consensus seems to be that a good-quality yet inexpensive soldering station with temperature control is the way to go.  The  Xytronics AUTO-TEMP 379 that Marty mentioned is a favorite of many around here, and I can personally vouch for it; it's wonderful.
Here are some links to threads discussing recommendations for soldering irons and stations:
http://www.diystompboxes.com/smfforum/index.php?topic=41150.0
http://www.diystompboxes.com/smfforum/index.php?topic=25852.0
http://www.diystompboxes.com/smfforum/index.php?topic=16220.0
http://www.diystompboxes.com/smfforum/index.php?topic=19096.0
http://www.diystompboxes.com/smfforum/index.php?topic=15940.0
http://www.diystompboxes.com/smfforum/index.php?topic=23073.0
http://www.diystompboxes.com/smfforum/index.php?topic=36061.0
http://www.diystompboxes.com/smfforum/index.php?topic=21679.0
http://www.diystompboxes.com/smfforum/index.php?topic=31611.0
Hope these help, and good luck with whatever you choose.
(Go with Xytronics!)
dosmun
Circuit specialists have some nice stations that are priced very well.
I got this one and have been very happy with it.
http://www.circuitspecialists.com/prod.itml/icOid/7307
