Tonepad Rebote Delay 2.5 questiion
Started by hari, April 03, 2006, 05:47:47 AM
hari
I ask friend to build Rebote Delay 2.5 from Tonepad, but I Can't find some parts value such as: Resistor 240 K, 510 K, Capasitor 0.082 uf, 0.027 uf, 51 pf
Electronic store here said that those are "strange" value..
Can I just replace them with the other value, 240 K = 270 K, 510 K =  560 K etc. ?
thanks for answering
peace...
gak
i don't think that changes will make big difference
or you can always achieve closer values adding resistances in series, eg: 220k + 22k, 470k + 39k... etc
the only substitution i've made on my rebote delay was a 47pF instead of the 51pF cap and i can't compare results but all can i say is that stills sound great!
go ahead!
cheers
gak.
boogietube
For caps, I usually go to :
http://www.justradios.com/orderform.html
Awesome service!
For Resistors and caps (some wierd cap values - all resistor values), I order from:
www.futurelec.com
Don't expect a quick turnaround from futurelec. They take a while.
Also, the best mica site including the ELUSIVE 51pf cap!!
http://www.circuitspecialists.com/level.itml/icOid/3433
Good service.
Switches transistors and other various stuff from Aron or Small Bear.
(you probably already know that)
Hope this helps!!
Sean
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
boogietube
Sorry I made an error:
www.futurlec.com is the right address.
Bron-Y-Aur-Stomp
first of all, the resistors falls in the 5% range
hari
well thanks for help
Gak, I heard one of your MP3 samples, it sound great.
thanks
peace...
