Nasty buzzy distortion needed!!
Started by stoooooo, April 07, 2006, 09:57:28 AM
stoooooo
I have been trying to figure out a way of reproducing in a switchable pedal the really nasty buzzy clipping produced when driving a mixer channel input too hard (specifically gain up full, set to mic input but using a guitar).  The sound breaks up in quite a harsh way but doesnt increase sustain like a fuzz pedal.
I have tried loads of different fuzz, distortion and overdrive pedals but can not get this sound.  The nearest I can get is a smokey amp with a virtually dead battery used to drive a bigger speaker (fine for recording but I need it in a pedal and the output from the smokey is too high to alow switching between smokey and a clean channel).  I am reasonably capable when it comes to building pedals.
Any ideas????
JimRayden
Try this one. It most propably will not sound like a mixer but it sure sounds nasty. I mean the buzz box at the very bottom of the page.
http://www.home-wrecker.com/bazz.html
Jimbo
RedHouse
Plug into a mixer then if that's the way you know to get it.
Then get the schem for the mixer and dupe a channel.
stoooooo
Thanks for the suggestions.
Buzz Box sounds nasty - but not quite right.
I have thought about building a mixer channel to get the sound but the schematics I have seen are quite complex as I would need to include the mic preamp (as this is what is distorting I guess).
I suppose I need something like a mic preamp but with an output level adjustable to match the direct guitar signal (i.e. to avoid unwanted changes in level when in bypass - as it would be true bypass).  Any ideas anyone?
rocket
Hi,
what you need is just a hard clipping amplifier (e.g. simple 2 or 3 Transistor stages with no feedback, or an opamp)  and a full range speaker.
A guitar speaker always make the sound more or less mellow because it acts as lowpass filter at ~ 5kHz.
If you record any overdriven preamp will do.
PenPen
Quote from: hank reynolds 3rd on April 07, 2006, 11:53:08 AM
try here,maybe???
http://www.diystompboxes.com/smfforum/index.php?topic=40917.0
Possible mods for the above, try increasing the cap C3 to 0.1uF for more of frequency passthrough, at the expense of some buzzing. Alternately, lower the value a bit to increase the frequencies that buzz. I've also considered replacing R1 with a diode a la the Bazz Fuss for even more nastyness, but I haven't tried that idea yet.
stoooooo
Thanks for the tips guys - on my way to Maplins.....
