Single frequency boost
Started by omt, April 09, 2006, 06:32:47 AM
omt
What i want to do is build a one band eq that can boost or cut around 1100 Hz can anyone point me in the direction of how to do this?
How tight a range around 1100 Hz (i.e. what Q value for the filter?).
The simple thing is to make a one-band graphic EQ either of the inductor/capacitor sort or a constant-Q version. Both can be done without real inductors, but the constant Q version is probably better for higher Qs, above 2-3.
omt
#2
If a a q-range is what i think is what i think it is i am looking for a range on 100-200 hz
Ge_Whiz
Mr.Huge
Here's an oldie but a goodie!
Now, this only boosts...
http://aronnelson.com/gallery/album12/Freq_booster
-Mr. Huge
BEN:   Mos Eisley Spaceport. You will never find a more wretched hive of scum and villainy. We must be cautious.
LUKE:   But I was going into Toshi Station to pick up some power converters...
VADER:   I find your lack of faith disturbing.
phaeton
Stark Raving Mad Scientist
Quote from: phaeton on April 11, 2006, 04:16:56 PM
OMG!! Craig with hair!  :o
And no beard...
It's good, simple, flexible and quiet, but it doesn't offer tons of boost.  In fact it provides less than a typical graphic EQ slider.  If that's enough, go for it.
phaeton
Quote from: Mark Hammer on April 11, 2006, 04:29:16 PM
And no beard...
Craig's beard, or Craig's circuit?
Btw, I assume someone just as easily drop in a TL0?2 or similar instead of the LF353....  And/or use a quad chip- build this one one half and use one of the others for another boost stage, etc..
Mr.Huge
This is one of the first projects I build as a young lad!
-Mr. Huge
Quote from: phaeton on April 11, 2006, 04:33:10 PM
Good point.  In fact, there is no reason why several stages couldn't be cascaded with the option to apply boost all over again at the same centre frequency.  You can pretty much string 'em out as far as you want, within reason, and give them the same boost frequencies or different ones or both..
Grab yourself a TL074, and wire it up for an input buffer, two cascaded frequency boosters and a Dist+ clipper at the output.  It'd be a helluva tone monster, with nice ZZ Top "gronky" sounds at the touch of a toggle or stompswitch.
In fact, this thing that I made last summer and presented to David Lindley is a combination tube sound fuzz and frequency booster.  I had the extra op-amp just sitting there.  I figured "What the hell".
http://img.photobucket.com/albums/v474/mhammer/49-er-A.jpg
http://img.photobucket.com/albums/v474/mhammer/Forty-Niner.gif
You will note that the unit has a bypass for the whole thing and an engage/disengage switch for the booster. (I used a SPDT but a 3PDT could engage 2 boosters and a status LED).  Gives a lot of nifty sounds, not the least of which is an "instant Mercury Blues".
RDV
You mean Craig doesn't look like that anymore? I must be really old now.
RDV
