transistor socket mounting
Started by jeff g, April 10, 2006, 10:05:48 PM
jeff g
how do you mount the 3 pin triangular transistor sockets so that they fit in the straight line layout of most pcbs?
powerplayj
I don't ........although if you etch your own PCB's you might could extend the middle pad using MS Paint.
I use the Mill-Max sockets that come in rows of 20.  Then just cut three (in a row) off of the 20.  These are available from mouser, small bear and probably radio shack.
builds completed: boutique fuzz, rangemaster, BSIAB2, PT-80, Tonepad wah, Ross Comp, Axis Fuzz, MOSFET boost, Thunderchief, Big Muff (triangle), Mr. EQ, Dr. Boogey,  Neovibe, Dist+, EA Tremelo, ADA Flanger, RM Octavia
next build(s): ???
3/4 North
How do you cut those things? I've tried and the plastic just shatters.
twabelljr
I've had good luck scoring them on both sides with a razor, then just snapping a piece off with my fingers. Without scoring first, sometimes they break into the pin area.
Shine On !!!
jrem
I use a dremel tool and a cut off wheel . . .     invaluable.
geekmacdaddy
What are the risks of using the sockets without the plastic around it?
twabelljr
QuoteWhat are the risks of using the sockets without the plastic around it?
No different than soldering the transistor directly to the board and having the leads exposed. Similar to individual "Molex" terminals. Don't let them touch each other or anything else.
Shine On !!!
finkfloyd
Quote from: 3/4 North on April 11, 2006, 08:07:43 AM
I use a set of nailclippers, they are also handy for cutting leads etc,
