NE570 replacement?
Started by Peter Snowberg, April 25, 2006, 05:09:26 PM
Peter Snowberg
Does anybody know of a good functional substitite (not pin-for-pin) for the NE570 compander?
I tried the search function, but it was not my friend today.
Eschew paradigm obfuscation
MartyB
Peter,
  I found SA570 or NE570N or NE572.
HTH
Marty
johngreene
#2
I've been doing a lot of searching for this kind of chip lately for a project and all I've been able to find are:
http://www.magnachip.com/ENG/Products/Standard/MixedICs/Phone/GL6552.html
http://www.samsung.com/Products/Semiconductor/SystemLSI/Telephone/CordlessPhone/S1T8507C01/S1T8507C01.htm
http://www.freescale.com/files/archives/doc/data_sheet/MC33111.pdf?srch=1
http://www.lansdale.com/prdmot8.htm This company appears to make the MC33111 now.
http://www.mitsumi-components.com/english.html MM1100 MM1102 MM1077
SA8507     Silan
DBL5020    daewoo
BA7725      rohm
LA8632      Sanyo
edit: forgot about That Corporation. http://www.thatcorp.com/4301desc.html
--john
puretube
Philips got/had some up-to-date low power/voltage, smd audio-processor stuff...
SA572
SA571
SA5752
SA578
SA577
SA576
SA575
http://www.search.philips.com/search/search?q=compandor&s=semi&l=global&h=semi
johngreene
Quote from: puretube on April 25, 2006, 07:02:24 PM
SA572
SA571
SA5752
SA578
SA577
SA576
SA575
On Semiconductor makes all of those now.
http://www.onsemi.com/PowerSolutions/parametrics.do?id=969
--john
Just in case some naive observers may not grasp the subtleties here, by "functional", you mean a chip that does the "same thing", more or less, but: a) does not have the same pinout, b) may require different signal conditioning at both input and/or output, and c) may require more or fewer external support components to accomplish what it does.
This is NOT the same as proposing that a pair of LF353 FET-input dual op-amps can sub for a TL074 quad bifet op-amp.
Ethan
A single channel device is nice. But it's really bizzare - they have two part numbers, one a compressor and one an expandor, but the typical circuits show identical internal arrangements, only the external parts are hooked up differently.
Peter Snowberg
Thanks for the replies! 8)
The PT2395 is still made so I was hoping to find a current make of compander to join with it.  :icon_biggrin:
Nasse
johngreene
You can order the whole family of NE570 devices from On Semiconductor. Just received my low-voltage 575s last week.
--john
redeffect
OK, lets get right to the point. Is the reason you want to use something different than the 570/571 an availability/ performance issue? Or; you "just want to do something different"? (I can relate to that...)
red
Peter Snowberg
Thank you Nasse. I was looking for a currently manufactured devices and thought all the NE570s out there were NOS parts by this point.
Big thanks again for the sources and substitutes. 8)
