Foxx Tone Machine ?
Started by steve b., May 01, 2006, 11:28:01 AM
steve b.
I just built this   http://aronnelson.com/gallery/Toneys-Album/Foxxv4   and have no sound. I noticed Q1 collector is .22 volts instead of approx. 2.22. All other voltages are in the ballpark of what's been posted. Where would i look to up the voltage on Q1's collector. Also would this give me no sound or do i have other problems ?  thanks for any info ---- steve b.
hairyandy
The first thing I would check is your connections, especially that you have a good ground connection everywhere.
Andy Harrison
It's all about signal flow...
Hairyandy's Layout Gallery
Toney
 Ok, check you in pinout on the trannies.
Check R6 is the correct value.
Go over your build with a magnifying glass for soldering errors.
Clean between the vero strips and check for shorts with a DMM.
Check wiring.
Then.... if no joy, post as per the sticky at the top of the page.
