DIY Layout Creator - software for easy drawing PCB, vero and perfboard layouts
Started by bancika, May 01, 2006, 08:00:21 PM
GodSaveMetal
Quote from: bancika on January 30, 2011, 04:33:07 AM
it opens v1 files but only reads those components that are available at the moment.
Btw, I added two type of transistors and LED, stay tuned  :icon_wink:
They are not available in the 3.0.4 beta version!!!! you have to post a new version with that components??? please!!!! thanks you have doing a best work!!!!!
bancika
Quote from: mhartington on January 30, 2011, 10:59:05 AM
So i just downloaded it and when i tried to open it I got a message that said there was an error and the file couldn't be open. I read the note on the site about having to do something with the MAC terminal but...to quote Mccoy in some sense, im a diy pedal maker, not a computer exert  :D How do fix the mac problem?
open the terminal, type cd <path to diylc directory>
then type ./run.sh
cheers
mhartington
Quote from: bancika on January 30, 2011, 11:48:20 AM
then type ./run.sh
cheers
im doing that and i keep getting "no such file or directory exsist"
bancika
did you extract all the files from the zip? You should have diylc.jar, lib directory with a couple of files and library with one more.
Also, do you have java 1.6 installed? It definitely works on mac, few people have confirmed.
cheers
bancika
Quote from: GodSaveMetal on January 30, 2011, 11:01:16 AM
3.0.5 is out, knock your self out :)
phector2004
Cool! I like the template idea
It would be nice if the component defaults could change between stompbox-sized and amp-sized depending on eyelet/perfboard, etc
Keep up the good work!
bancika
templates will be much more useful once I'm happy with the component set. I'll include a couple that can really save time in some situations and users will hopefully add theirs.
As for different defaults, you can do it now with two config.xml files (auto-created by the app). One with amp-sized defaults, other with stompbox or whatever. You'd just put the one you want to use, start the app and it reads defaults from there. Hope it makes sense.
fatfoohy
ahhh thank you, that fixed it!
Edit: i just downloaded 3.0.5, and it's sweet! i love how the resistor color codes change
having leftover parts is just proof that you made it better!!!!
GodSaveMetal
Yeah the new version 3.0.5 it alright but Wat happens with the recognition of the led with version 1?? it's not compatible???
bancika
could you add the ability to import pictures of scarlett johannsen cooking a casserole......  :icon_mrgreen::icon_wink:
GodSaveMetal
Quote from: bancika on January 31, 2011, 04:55:47 AM
ok, ok, relax  :icon_rolleyes:
Excuse me and thanks!!!!  for all your work!!!!!! your great!!!!LET THE FORCE WITH YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!
bancika
Big Dan
Hi,
Looking forward to trying out your awesome program!
Edit---figured out my problem...run as admin... :icon_mrgreen:
vendettav
nice software actually. im using the new one...
the only thing was errm could you add sockets for trannies or something?? or meh whatever it's already supercool ;)
check my music HERE
Shredtastic psycho metal!
GodSaveMetal
I tried the new version and it is approx 90% compatible to the V1; the potentiometers and the switches are not compatible with the new version; the LED are yet compatible!!! great work congratulations Its easy to work!!!! and more speedy!!!!! thanks a lot forthese new instrument; I'm looking for the finalversion to do my METAL MUFF!!!!! please only this program can do this!!!!
jdub
Once again, Bancika, you've done a fantastic job.  Love the new look and functionality.  Kudos!  I envy your computer-fu.  :-*
Quick question:  the new version should open v2 files, correct?  I tried opening a couple and, while the viewing area shifted slightly as though a file was opening, nothing was displayed.  Is there somethinng that needs adjusted before v.2 files will open?
Thanks again!
A boy has never wept nor dashed a thousand kim
my 2p worth..
i think i prefer the layout of version 1...with all the components and jacks etc...in the left column
but i like version 2 for drawing schematics.....great programs either way... just my preference i guess!..
now if we had the combination of all 3 and could choose which visual layout we prefered, and it was all backward compatible ..that would be superb.. :icon_wink:
bancika
Quote from: jdub on February 16, 2011, 12:02:49 PM
Thanks again!
Thanks man.
v2 import is still not functional, but will be.
Greenmachine
Thank you Branislav.  Excellent program and I look forward to using it.  :icon_biggrin:
