Author
Topic: New Effect: Payback (Read 38404 times)
TheAttackman
sorry to be a pain.. but i read through everything and i cant tell exactally which layouts are confirmed  could someone help me out thanks
Logged
abakuzam
Hello everyone, I posted a new effect called Payback at the site. It is a looping sampler with a host of features. There is article explaining it's operation and several modification suggestions. Enjoy. The Tone God's DomainOh and about that little challenge:  how can i disable multiple recording on paybackv1? thanks   Happy Canada Day to all my fellow Canadians. Happy 4th of July to all my brothers and sisters to the south as well. Your Tone God, Andrew
Logged
Jaicen_solo
When I'm back on a pc, not iPhone, I'll look up the schem, but if i remember correctly, it really is as simple as tying the address pins to ground.
Logged
abakuzam
thanks a lot , don't forget
Logged
The Tone God
Global Moderator
Linda
Yep. All the loop number switch does is set the address pins to the right value for roughly half the memory location to start from. Setting them all to ground starts from the beginning.
Andrew
Logged
abakuzam
Andrew
a2,a3,a5,a8 pins directly to ground right? it will give me 60 sec loop? my english not good , i did'nt understand well , sorry. and, do you have verified pcb layout for v.1? i saw very tight pcb layout for v1 in earlier posts. is it verified? thanks a lot
Logged
The Tone God
Global Moderator
Linda
and, do you have verified pcb layout for v.1? i saw very tight pcb layout for v1 in earlier posts. is it verified? Yes connect all the address pins (A0-A9) to ground. I don't have a verified PCB layout myself but there ones out there. Good luck!  Andrew
Logged
abakuzam
and, do you have verified pcb layout for v.1? i saw very tight pcb layout for v1 in earlier posts. is it verified? Yes connect all the address pins (A0-A9) to ground. I don't have a verified PCB layout myself but there ones out there. Good luck!  Andrew thanks, i found this layout http://www.mediafire.com/?cobl8lxkqfr61gvit seems right to me what do you think?
Logged
