|AMPAGE| |GEOFEX| |AMZ|
May 19, 2013, 02:05:44 AM
890668 Posts in 97538 Topics by 28664 Members
Latest Member: jetmarshall
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  New Effect: Payback 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: 1 ... 5 6 7 8 9 [10] 11 12 13 Go Down Print
Author Topic: New Effect: Payback  (Read 38394 times)
Auke Haarsma
TooMuchGear?
Re: New Effect: Payback
« Reply #180 on: December 23, 2007, 03:13:10 PM »
I've made a soundclip of the quality I get when I have it on the breadboard. Can anyone confirm this is the actual soundquality?
You can hear the clip here:
http://profile.ultimate-guitar.com/toomuchgear/music/
The 'clean' parts are a clean guitar looped via my DD20. The 'not-so-clean' parts are looped by the Payback.
Logged
Valoosj
Yorick
« Reply #181 on: December 23, 2007, 03:16:22 PM »
Isn't your recording volume too high? I read something about it with the lo fi loop junky...
Logged
Quote from: frequencycentral
You squeezed it into a 1590A - you insane fool!  icon_mrgreen
Quote from: Scruffie
Auke Haarsma
TooMuchGear?
« Reply #182 on: December 23, 2007, 03:27:09 PM »
I don't think so. I have this level of distortion with the rec level high and with the level low. The difference in volume in the clip is caused by me adjusting the playbacklevel-pot.
Logged
Auke Haarsma
TooMuchGear?
« Reply #183 on: December 23, 2007, 03:36:36 PM »
Well, I rechecked after your comment. It appears the playback level and the recording level interact. If I record with playback level at max and recording level at 'normal' I get a lot of clipping. If I lower the playback level while recording I get a cleaner sound.
However, it doesn't get much cleaner than the first sample of the clip. Then again, it's a lofi-looper.
And it doesn't loop btw, just one playback and then it stops.
Logged
Valoosj
Yorick
« Reply #184 on: December 23, 2007, 04:04:11 PM »
then you must be doing something wrong Smiley which is good, since then there is room for improvement.
Logged
Auke Haarsma
TooMuchGear?
« Reply #185 on: December 24, 2007, 01:54:48 AM »
yeah, could very well be the case. I can trigger playback by touching ground anywhere with my hand. The logic seems very sensitive. I guess it works as designed when boxed.
Logged
Valoosj
Yorick
« Reply #186 on: December 25, 2007, 02:27:34 PM »
Do you keep it grounded? If not that might be why it only plays back once
Logged
Valoosj
Yorick
« Reply #187 on: January 15, 2008, 04:04:04 PM »
Ok, I had a go at making a pcb. Could somebody help me find any errors?
Just say which component is wrong, and how it should be, I still have the file in layout creator.
Logged
The Tone God
Global Moderator
Linda
WWW
« Reply #188 on: January 16, 2008, 11:02:22 PM »
Just an update. I noticed that Digikey is not stocking any of the ISD1600Bs now. Trouble is brewing.
Andrew
Logged
Valoosj
Yorick
« Reply #189 on: January 17, 2008, 04:53:47 AM »
Indeed. I received an email from them one week after I got my ICs in. But I think they can be found at other places.
Logged
Valoosj
Yorick
« Reply #190 on: January 18, 2008, 09:14:56 AM »
Schematic has been checked by Auke Haarsma, I edited according to his instruction, I think this should be it now.
Logged
Valoosj
Yorick
« Reply #191 on: January 18, 2008, 01:15:43 PM »
CRAP!  Gate 10 of the ISD needs to get his 5V. I forgot this on the schematic. Errors keep popping up!
Any body else that spots something?
« Last Edit: January 18, 2008, 01:46:24 PM by Valoosj » Logged
Valoosj
Yorick
« Reply #192 on: January 22, 2008, 12:43:12 PM »
Last time (I hope). Now it should be correct.
Logged
Valoosj
Yorick
« Reply #193 on: February 20, 2008, 04:39:14 PM »
I just finished soldering, something is wrong. I hook up the power to the pedal, the led goes on, and after 20 seconds it goes out. Pushing the record/play button doesn't change the status of the led.
Logged
Valoosj
Yorick
« Reply #194 on: March 31, 2008, 06:17:46 AM »
Tonegod, are you still there? I sent you some PMs, with the layout and a vid of what is going wrong. Apparently it's a grounding problem of some kind, but I can't find out what went wrong. I did everything I normally do.
Logged
cloudscapes
Etienne B
« Reply #195 on: February 17, 2009, 08:18:33 PM »
appologies for the necro-bump. I've been having trouble with this build I've partially breadboarded. I'm doing v1.1.
http://www.geocities.com/thetonegod/payback_v11/payback_v11.html
I haven't done any of the opamp buffer parts. for now, I'm just doing the recording and looping logic. started with the recorder, and by grounding pin 2, I succeeded in making it record a short clip, and grounding pin 2 to play it back! with that part of the circuit working, I put it aside and did the 4093 logic. unfortunatelly when I hooked it up, it doesn't work anymore. the record led blinks rapidly for half a second (shorter duration and more rapidly than normal record blinkage) and the led around the 14093 stays on at all times when I have power hooked on.
I couldn't find a place in town that had 4093's so I got 14093's instead, which as far as I can tell are the same thing. is this a problem? you should consider me a total noob at logic switching with these types of components.
I noticed the tone god's post about mislabeled pins
http://www.diystompboxes.com/smfforum/index.php?topic=65575.0
but I'm really confused.  Embarrassed
I've found datasheets for both the 4093 and 14093 and neither of them are the same pinouts, and as far as I can tell neither of them would "support" tone god's advice to switch pins 8 and 10, and 4 and 6. if I did either of these, it seems like the layout diagram would change "logic" in the v1.1 circuit.
http://ece-www.colorado.edu/~ecen4618/cd4093b.gif
http://pdf1.alldatasheet.com/datasheet-pdf/view/11974/ONSEMI/MC14093.html
what should I assume to be true? the pin number swap, or the little pictures representing each of the four triggers, regardless of the pinout?
« Last Edit: February 17, 2009, 08:22:09 PM by cloudscapes » Logged
{DIY blog}
{www.dronecloud.org}
The Tone God
Global Moderator
Linda
WWW
« Reply #196 on: February 18, 2009, 01:22:11 AM »
The diagram symbols are correct. Its the pin numbers on the symbols that were messed up. So match the symbols to you datasheet and adjust from there.
Andrew
Logged
cloudscapes
Etienne B
« Reply #197 on: February 18, 2009, 05:59:45 AM »
alright, thanks!
I matched the symbols and it know works. thank you muchly!
Logged
{DIY blog}
Valoosj
Yorick
« Reply #198 on: February 18, 2009, 08:20:20 AM »
Does your payback work? I spent about a year trying to get it to work, but it never fully did.
Logged
kierc
Kier
WWW
« Reply #199 on: February 18, 2009, 08:22:59 AM »
Where can I get this ISD? would love to build this  Sad
Logged
Pages: 1 ... 5 6 7 8 9 [10] 11 12 13 Go Up Print
« previous next »
Jump to:
