GREEN RINGER PERFBOARD AND PCB LAYOUTS...
Started by Dragonfly, July 05, 2006, 03:09:28 PM
Dragonfly
awaiting verification, but should be correct...original schematic is at www.generalguitargadgets.com
AC
Seljer
Thanks, I've been meaning to build this one on perfboard for a while :)
bancika
$uperpuma
Listen, I can't build em that fast :)  Dragonfly and Bancika's overachievements rock our world again
Dragonfly
...if you check Bancika's website, in the "layouts" section there are several new ones added...i just added a super small Duende JFET boost perf/pcb as well....
AC
newbie builder
Sweet- perfect timing for a perf layout since I was just about to build one of these and didn't wanna make my own layout! Nice work!
Dragonfly
gaussmarkov checked through the layout and didn't find any errors, so BUILD AWAY !!!!
AC
Fret Wire
#7
Andrew, one question and one suggestion:
Did you add the big text at the top with the DIY software, or did you use MS Paint?
With a pcb that has only V+, Gnd, In, and Out pads, I'd add a few more gnd pads along the bottom to cover jack, switch, LED, and pot (n/a this ckt) grounding needs. Much nicer than soldering all gnd connections to one pad.
Btw, Bancika.....excellent job with the software. :icon_smile: I use Express for schematics and pcbs, but my vero stays on graph paper because I hate pasting, dragging and dropping on MS Paint. Now I can do some vero too. Thanks again!
Fret Wire
(Keyser Soze)
  I do like at least two pads for ground...it tends to get worked on, , re-heated...I find ground easy when I run an arched wire above board between two perf pads...Good V+ access I like also, because I find myself going from battery supply to PS, and ocassionaly back again to battery/adding circuits..so I make  these points easy to identify and connect to.
bancika
Quote from: Fret Wire on July 05, 2006, 05:01:29 PM
With a pcb that has only V+, Gnd, In, and Out pads, I'd add a few more gnd pads along the bottom to cover jack, switch, LED, and pot (n/a this ckt) grounding needs. Mush nicer than soldering all gnd connections to one pad.
Tnx :)
Big text is added by program automatically...
Dragonfly
DIY software
i've done that on a few layouts...most recently the Minibooster layout i submitted...i'll start doing it more often...
Dragonfly
Quote from: petemoore on July 05, 2006, 05:09:04 PM
noted...thanks Pete !
AC
Fp-www.Tonepad.com
www.tonepad.com : Effect PCB Layout artwork classics and originals : www.tonepad.com
Dragonfly
Dragonfly
wow ! it definitely has some similarities...i worked off the GGG schematic...pretty much worked it straight across, as i'm sure you did...
i can assure you that in no manner, way, shape, or form, did your layout influence me...i hadn't looked it till just now...however, out of respect for you and the work you've done, i will remove my layouts if you wish (which sucks, 'cause then i've wasted my time...but oh well)
let me know if you'd like me to remove it....
AC
Fp-www.Tonepad.com
No problem. You're right, it's the logical way to lay the board from the schematic. But they do look similar :)
And I hope to influence the other guys making layouts, that's the whole point.
I guess I assumed too much. ::)
Rock on! ;D
Dragonfly
Quote from: Fp-www.Tonepad.com on July 05, 2006, 08:09:26 PM
Rock on! ;D
no worries, bro....we're all working toward the same goal...to learn, and hopefully help others learn as well.
AC
btw..for those who "haven't" visited www.tonepad.com , you should...it's full of great FX and amp projects !
