Author Topic: the best replacement wah pots?  (Read 21904 times)
somis9
  • Guest
« on: July 24, 2006, 01:54:48 AM »
Give me your opinions. What is the best wah pot out there for me to put in my Vox 847?
Im looking for smooth movement and taper.
moody07747
Re: the best replacement wah pots?
« Reply #1 on: July 24, 2006, 02:19:08 AM »
correct me if im wrong but if i recall correctly its a liner taper pot in a wah.
any 100K pot should do the trick but get something heavy duty.
i know i saw one today but im looking now and forgot where it was...someone else will chime in soon
Dave
http://sonicorbstudios.squarespace.com/
Sonic Orb Studios
The Media Specialist
alderbody
« Reply #2 on: July 24, 2006, 02:39:25 AM »
I like the fulltone Wah pot.
It's 100K and it's not linear.
It has a custom taper.
Very durable in terms of long time use, but be careful with the soldering iron.
sfr
« Reply #3 on: July 24, 2006, 07:50:30 AM »
In terms of long time usage, I like the Clarostat-style conductive plastic pots.
« Reply #4 on: July 24, 2006, 08:06:59 AM »
When people talk about wah pots, what they are often talking about is the sense of smooth control over wah centre frequency.  That is certainly a product of the pot, but also a function of the mechanical coupling of foot-to-pot.  On my own home-brew wah, I'm fine with the pot taper and tone, but the mechanism seems to "grind", reducing the sense of immediate control one desires.
Which leads me to ask the question: When it comes to the rack and pinion systems that translate foot motion to pot movement, what sorts of choices are there in the available parts?  I mean we see varieties of gear ratios in guitar tuners.  Are there options available in terms of gear ratio in rack and pinion systems?  Are there better and worse ones?  For instance, does a wider mechanism that distributes foot pressure over a broader portion of the pot shaft feel "smoother"?
I just find it odd that we spend so much time discussing the thing being controlled, and so little time and effort discussing what lets us control it.  It starts to be a bit like talking about precision drill bits and never once bringing up the topic of drills, chuck quality, etc.
alderbody
« Reply #5 on: July 24, 2006, 09:42:18 AM »
I don't remember seeing any alternative rack and pinion systems with different ratios.
I believe that the Wah pedal requires some magic in the foot, except for the electronic parts, in order to make it sound good.
I mean, if the player just bounces the rocker up and down all the time, what's the need of a man controlled wah instead of an auto-Wah?
Great Wah sounds come when you spend some time to discover the taper of the pot more "deeply",
so to move the rocker within areas of the sweep that bring the "magic" out better...
I have done that in mine, and i can say that the experience is really great.
I also found that i can "interact" with the pedal better when i play barefoot...  :icon_mrgreen:  (yes, i wash my feet)
this way there's nothing between my foot (size 11+) and the pedal, so every little motion can be transfered to the shaft of the pot...
btw, (foot) size matters....
regarding gear ratios, i guess they got it right back then when they first made the Wah Wah pedals, so why worry?
Paul Marossy
« Reply #6 on: July 24, 2006, 10:03:34 AM »
You know, honestly, I think the Dunlop Hot Potz II is the best that I have tried. And they last forever, too.
somis9
  • Guest
« Reply #7 on: July 24, 2006, 12:19:24 PM »
thanks for the feedback guys.
as for what Hammer was saying, I took my v847 completely apart and lubed all moving parts up with graphite, especially the rocker hinge. It helped a lot. and I made sure there wasn't too much pressure from the piece that holds the rack against the pinion. but when I had the pot out I knew thats where the problem was. It just didn't have smooth movement.
If there's anything else out there I'd like to hear it. Right now I'm thinking I'll go with the Fulltone, I like the way the Clyde feels.
formerMember1
  • Guest
« Reply #8 on: July 24, 2006, 08:00:33 PM »
Paul, I like your thoughts on wahs,..  :icon_smile:
how do you like the hotzpotz II compared to the Blacktop or Propot?  As far as being close to the old Vox Clyde McCoy wah pots... (ICAR)
vanessa
« Reply #9 on: July 24, 2006, 09:09:41 PM »
I've come across a 200k Hot Potz II that I liked even better than the 100k (I think they use it for some volume pedal they make). Another one that's my all time favorite is the Dunlop re-issue ICAR 100k that they are putting in the new VOX Clyde McCoy's. I don't like the Fulltone versions at all. The Teese Roc-Pot and the knock-off Pro-Pots are very good too (I hear they are both made by the same company [CTS] and are identical with just the names stamped as the difference) both being 200k.
« Last Edit: July 24, 2006, 09:11:15 PM by vanessa »
Paul Marossy
« Reply #10 on: July 24, 2006, 10:02:13 PM »
I don't know how they compare to the old Clyde McCoy pots, but I like how they sweep the best of the ones that I have tried (and I haven't tried them all). The ProPot replacement in my Vox Wah is OK, but the sweep doesn't seem as wide as the Hot Potz II is.
Hmm... I didn't know that they made a 200K version.
vanessa
« Reply #11 on: July 24, 2006, 10:49:21 PM »
I ordered a 100k Hot Potz II a while ago and the company I bought it from sent me a 200k by mistake. They said it was for a Dunlop volume pedal but I've never been able to find out which one. I got to keep it for free (yea!!!) and got a 100k replacement. It has a much nicer sweep over the 100k Hot Pots II. The Roc-Pots/Pro-Pots have a very similar sweep but I suspect the 200k Hot Potz II is made better.
« Reply #12 on: July 25, 2006, 08:46:21 AM »
I still think that folks should temporarily pop the back off their wah pot and apply some of this Stabilant stuff I keep ranting on about.
Keep in mind that no matter HOW fabulous the pot is, the fact remains that the pot works by having a wiper (note the name) that rubs against the resistive element.  Obviously you can have better and worse resistive elements and more and less abrasive wipers (REALLY good pots seem to have wider resistive elements and consequently wider wipers with multiple independent contacts, kinda like those 2-Tek bridges), but the fact remains that pots work by one thing rubbing against another.  And wah pots work by having that thing rub a LOT.  As pots go, think about how many times in one night's gig you might move your guitar volume pot backwards and forwards.  Now compare that to how many times a wah pot gets moved back and forth over the same period of time.
All that rubbing erodes the resistive element, and eventually you get those little micron-wide gaps in contact.  They're not huge, and a well-designed wiper system will be able to overcome such erosion and still maintain reasonably good contact, but even so, such teeny tiny gaps can be like jumping across a gorge for the signal.  Stabilant coats the surfaces and fills in that gap.  It also provides a certain amount of viscosity.
Of course, it bears noting that we are talking about multiple dissociable pot parameters here:
1) The usable crackle-free lifespan
2) The mechanical feel
3) The resistive taper
Treatment of the resistive strip will address #1 but not the other two.
Paul Marossy
« Reply #13 on: July 25, 2006, 10:06:38 AM »
For me, the mechanical feel has mostly to do with the the workings of the wah shell. The pot is a very small part of the equation.
formerMember1
  • Guest
« Reply #14 on: July 25, 2006, 10:07:55 AM »
thanks paul and others..
I will have to look for that 200K Hotzpotz II.  Seems like it maybe good and reliable.
I think I never tried the Dunlop ICAR 100K,you say that is in the vox clyde reissues,..is that in the Dunlop GCB-95's too?
edit*
sometimes my wah will be stiff and rigid, and i have to physically readjust the angle of the pot to the gears, and on the propot's, if you put the 2 BIG washers together or on each side of the casing it feels different.
Paul Marossy
« Reply #15 on: July 25, 2006, 10:24:40 AM »
I have noticed that, but to me it's very subtle change. I think the reason it feels different is because of where that rack contacts the gear - the closer to the pot body, the less play it has and the further out you go, the more play it has (meaning how much the pot shaft can sway).
vanessa
« Reply #16 on: July 25, 2006, 11:04:32 AM »
I've found these Dunlop reissue ICAR 100k pots to be the best and closest to the original so far. They are made for the new reissue VOX Clyde McCoy and are made very well. Not as well made as the Hot Potz II or the Roc-Pots/Pro-Pots, but better made than the Fulltone pot. They do not put these in the GCB-95's, only in the newer reissue VOX Clyde McCoy.
rockgardenlove
« Reply #17 on: January 05, 2007, 12:01:42 AM »
Any body know where I can buy these ICAR Dunlops?
jonathan perez
« Reply #18 on: January 05, 2007, 12:04:18 AM »
mr hammer hit the nail on the head  ;)
(great time for a pun!)
rove
« Reply #19 on: January 05, 2007, 09:38:47 AM »
I just replaced the stock pot in my Dunlop Wah with one of the black top 200k pots from small bear.  I think that the pot in addition to the Teese mod to simulate the ICAR taper (switch the .22mf feeding the wiper with a .33mf) makes for an awesome sweep range, and much less expensive than the Hot Potz or even FT pots.
