vtl5c2 in the uk?
Started by snufkin, July 26, 2006, 11:15:42 AM
snufkin
is theres stockist of vtl5c2  in the uk
im making the temulus lune as my second project  :icon_frown:
or apart from self fabrication what is the best uk riplacement component?
thanks this forum is the best
PS i did a search of old posts and came up with the NSL 32 is that a good option? (sorry if this is an already answerd question)
easyface,phase 90,many fuzz faces,feedback looper,tremulus lune and so on soon to be ADA!
hank reynolds 3rd
Hi Snufkin,
the NSL32 should work fine with the Tremulus Lune...
You could get them from here:
http://uk.farnell.com/jsp/home/homepage.jsp
this is the cheapest place I found that sells them in the UK (£1.13) but you have to make a £20 minimum order with them....
both optocouplers you mentioned are available through Banzai..
http://www.banzaieffects.com/Optocouplers-c-311.html
They're in Europe ,and the delivery time I got with my order was just over a week...
snufkin
cool i hadnt thought about banzi and i was not sure if they were just US
the first project i did was a vero easy face and it wored first time  :icon_cool: all the parts i got were from a small electronics shop which has everithing the old guy helped me allot and has a load of ICs and stuff for fx pedal building
i did the vero before i read a tutorial on how it was done so i worked it out on my own but i did it in a strange way i copied the tonepad pcb diagram and joined the bits of the tracks with blobs of solder :icon_redface: any way it worked and sounds good
on the way back form the electronics store today i found an old computor and an amp used as part of an studio set up and a 70s record player
any way i salvaged them both for parts and now i have enough stuff to build another easy face
