Joe Davisson's Obsidian T vero layout
Started by Xavier, August 02, 2006, 07:58:19 AM
Xavier
I've been always curious about this circuit. It is said to be phenomenal through a SS clean amp (which is my case). I might give it a go. I can't remember having seen any layout for this project , so here it goes for all the DIY fellas here. :icon_mrgreen:
NOTE: There are trace cuts under R11, R12 and R17, which appear to be semi-transparent as they are under the resistors. This is how Bancika's software works.
What a GREAT piece of software, btw. It makes drawing these boards a breeze...
EDIT: Transistors have been rotated 180ยบ so now they appear exactly how they should be placed (flat side facing right). Thanks Dragonfly
  Hot Circuit !!!
  Verified?
  Thanks for sharing the work Xavier :icon_cool:
Xavier
I think it is now. After you asked I've corrected an error where I took Tone 3 before the 33K (not after).
I've corrected it and now it looks all well and good.....
Please let me know if you find out any errors, but again I think it's OK.
BTW the transistor pinout is CBE (from upper to lower)
I guess I'll build it at some point, but if anybody tries it first please let me know.
Stompin Tom
Thanks Xavier... I've been looking at this one, too. It'll probably be some time before I get a chance to build, though.
MartyMart
Nice one , Joe's circuits are fantastic !! :D
MM>
Dragonfly
Quote from: Xavier on August 02, 2006, 09:59:58 AM
its pretty easy to "rotate" the transistors 180 degrees so that they visually *appear* as you'd put them in...
REALLY nice layout, btw...
AC
Xavier
#6
Quote from: Dragonfly on August 02, 2006, 01:14:47 PM
AC
Done . Ask and ye shall receive  :icon_mrgreen:
BTW I've been checking the other circuits and they appear to be really similar. The Vulcan is worth the build after having tried the Obsidian? same kind of sound?.....
MartyMart
Build the "JFet Vulcan" that sounds different and is truely a superb high gainer :D
MM.
Xavier
Quote from: MartyMart on August 02, 2006, 01:46:26 PM
MM.
Thanks Marty !! How would you compare it against what is known alrady (Boogey, bsiab, chaos....this one I didn't like..)
hari
peace...
