Author Topic: PNP Germanium Transistor pinouts?  (Read 4787 times)
KerryF
« on: August 03, 2006, 12:42:29 PM »
Can someone draw me a diagram labeling the pinouts for a PNP Germanium transistor.  I am using these for the ColorSound ToneBender MKII Pro and im not sure where to put the transistors in.  I have 6 of these, because I am building 2 of the ToneBenders.  I have the values of each if thats needed.
markm
Re: PNP Germanium Transistor pinouts?
« Reply #1 on: August 03, 2006, 12:46:13 PM »
Check this post.
http://www.diystompboxes.com/smfforum/index.php?topic=47789.0
It developed into a wealth of info on trannies!
Jay Doyle
  • Guest
« Reply #2 on: August 03, 2006, 12:48:41 PM »
DIY FAQ link.
Near the bottom are transistor pinouts.
Actually, most of what people ask can be found in there or using a search.
« Reply #3 on: August 03, 2006, 12:53:30 PM »
  DMM Hfe checkers do the pinout verification thing well.
  Usually just turning them around once in the socket, PNP side and NPN side too...you probably won't have to twist two of the leads around to get a reasonable reading which shows pinout and polarity, a 'reasonable' [not accurate for calculating gain] Hfe reading.
Torchy
« Reply #4 on: August 03, 2006, 01:04:08 PM »
I did a quick search and found this thread ...
http://www.diystompboxes.com/smfforum/index.php?topic=44525.msg324038#msg324038
with this picture
KerryF
« Reply #5 on: August 03, 2006, 01:11:27 PM »
Thanks so much everyone.  And Torchy thanks for the diagram!
