Spyder Build Report
Started by Primus, August 08, 2006, 10:44:30 AM
Primus
Finally finished. Advice:
1. Make sure you know how to wire mains.
2. Don't attach the voltage regulator to the chassis, the heat sink is grounded and you will form a common ground which is the whole reason for building the spyder.
3. Use a PCB. I can't believe I point-to-point wired this thing...
