Seljer
Simon
find one of those value packs of a couple hundred resistors/capacitors on ebay or wherever, it gets you plenty of most common values, otherwise:
generally for resistors its something like 47, 100, 220, 470, 680, 1k, 2k2, 3k3, 4k7, 6k8, 8k2, 10k, 22k, 47k, 68k, 100k, 150k, 220k, 330k, 470k, 1M, 2M2, 4M7 most common ones you should order more of seem to be the ones based around 10 or 47
for capacitors ceramic - 10pF, 33pF, 47pF, 100pF, 220pF, 470pF, 680pF metal film/mylar/whatever - 1nF, 2.2nF, 4.7nF, 6.8nF, 10nF, 22nF, 47nF, 100nF, 220nF, 470nF, 680nF, maybe all the way up to 1uF electrolytic -1uF, 2.2uF, 4.7uF, 10uF, 22uF, 47uF, 100uF, and larger if you need them
potentiometers: 1k, 10k, 100k, 500k in both linear and log tapers
