True bypass or millenium?
Started by davph30, September 28, 2006, 02:12:51 PM
davph30
I've now built a few pedals using true bypass which seem to work great and helpfull if your battery goes.
What are the benefits of using Milenium bypass?
Dave
The Millenium Bypass is a version of true bypass. In addition, it gives you an LED indicator to show whether the effects is active or not, and does not require a 3PDT stomp switch to do this. It works with a DPDT stomp switch.
boogietube
Again R.G. rocks!
Millenium rocks!!
Cheaper and more fun too!
Sean
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
