Noob Stripboard layout question
Started by cacibi, October 04, 2006, 02:27:49 PM
cacibi
Just been lurking around and gathering some parts and tools.  Great stuff and can't wait to dig in on some projects.
My first question is regarding the stripboard layouts in the gallery - can someone clue me in on what the red-dot-squares mean?  Not sure if they are holes that just need to be filled with solder or if they are connection points for joining strips or what.
Hal
if you link, I could tell you for sure, but I think they're trace cuts
to cut a trace, take like a 1/8" drill bit, and with you hand, drill out the hole.
Or slice two points wiht a knife, and burn it off.  Both ways work fine.
343 Salty Beans
You mean the red dot in the middle of the red square, right? That's a trace cut.
cacibi
So the purpose of the trace cut is to interrupt the signal flow along the strip at that point?
Gilles C
Yes.
All the strips can be seen as parallel wires. The trace cut is like cutting a wire with cutters. You now have 2 separate wires after the trace cut.
Gilles
chemosis
what are the blue circles under and around the ics on the veroboard such as in this layout
I would say they are places where two wires go into one hole.
chemosis
thaose blue dots, or circles just show where 2 resistors and or jumpers are connected together and soldered into the same hole
chemosis
thanks alot blue bunny seriously.  i just seen your message after i already figured thats what they meant. that was the only conclusion i could think of. kinda a stupid question.thanks though
