Simple LED related question
Started by bancika, October 09, 2006, 07:00:24 AM
bancika
I'm little ashamed to ask this, but does it make difference if I wire current limiting resistor for LED on + side and - side. It stompbox I'm making it would be easier if I could tie it to negative lead.
Tnx
Gilles C
It doesn't matter. As long as both components are connected in series and that the LED still has the (+) and (-) sides in the same direction as before, it's the same.
(+)----/\/\/\/---->|----(-)    is the same as     (+)---->|----/\/\/\/----(-)
Gilles
bancika
Thanks, I was thinking the same but wasn't sure :)
Cheers
