Testing transistors II
Started by Chuck, October 10, 2006, 04:18:12 PM
Chuck
I'm not sure if anyone has seen this, but I recently purchased a Atlas DCA - Semiconductor Analyser.
This is the coolest thing.  Works great.  Using the RG mthod and this method gets the same results.
The Atlas DCA - Semiconductor Analyser just makes it super easy.  Attach the clips, bush the button.  It even tells you the pinouts.
http://www.peakelec.co.uk/acatalog/jz_dca55.html
Moonface
Yep. I have that and got the same results too. Phoking expensive tho...  :icon_evil:
aron
I don't think this works for Ge transistors and for FETs - maybe I am wrong.
Moonface
aron
Have you verified accuracy with Ge transistors? What does it show for JFETs?
Aron
Moonface
It shows exactly same results with RG tester when using germ trannies. For Jfets it doesn't usually detect which is drain or source. It recognises Mosfets tho.
aron
QuoteIt shows exactly same results with RG tester when using germ trannies.
hmmm.... I guess what I should have asked is does it only show hFE or does it show leakage as well? For me, leakage is almost more important than hFE. Well about equal.
Sounds like a cool and useful unit.
Moonface
Quote from: aron on October 11, 2006, 05:35:31 AM
It shows leakage and gain.
Moonface
Hmm. Lets see. Tested an OC76 with it.
Says:
PNP Germanium Transistor
RED   GREEN   BLUE
Emit   Coll       Base
Current gain Hfe=136
Test current Ic=2.50mA
Base-Emitter V Vbe=0.30V
Test current Ib=5.02mA
Leakage current Ic=0.23mA
Dat's it. ::)
Moonface
If you can find a Sencor "Cricket" transistor analyzer on ebay or in a closing repair shop, that does the same thing as well. Mine cost $35 on ebay.
Old tech, but it does the same thing analog-ly.
Stompin Tom
A little google search turned up this kit... seems to do the same thing. You'll have to put it together, but it's about a third the cost of the atlas. I'm not sure if I need it, but it really does seem pretty cool.
http://www.m3electronix.com/sa.html
alderbody
Quote from: Stompin Tom on October 11, 2006, 09:22:29 AM
That's a nice gadget, too!
and it's kinda DIY...  ;)
Chuck
Yeah, I know its expensive.
But at the rate I've been getting ge trannies, its worth it.
Plus without having datasheets on some of these, the pinouts is great.
Chuck
