Substituting 2n5485 JFET?
Started by Shannon, October 16, 2006, 08:40:46 AM
jfrabat
Quote from: alfafalfa on December 12, 2017, 10:04:49 AM
I saw a different schem that used quite different transistors.
https://ibb.co/hMLhnw
Couldn't it be a 5458  spelled wrong??
Maybe...  but I do not have 5458s anyway, so I will give the NTE a shot.  I can always replace it if it does not work...
Sent from my SM-G950F using Tapatalk
I build.  I fix.  I fix again.  And again.  And yet again.  (sometimes again once more).  Then I have something that works! (Most of the time!).
Kingmafw
it is mei sizzen net to dwaen
Johannes Harald Kingma - FWS Pedals - Germany
jfrabat
Tuvalu
Hi!
You can try to apply BF245A, BF245B, they are very similar to 5485.
Clint Eastwood
J113, or j112 should work, check datasheets. They are in the right Idss and Vgsoff range. And they are fairly easy to obain (Farnell)
