CMOS nyquist aliaser perf lay-out (not yet verified)
Started by birt, October 16, 2006, 11:30:53 AM
birt
here ya go:
i've built it myself but i did that in a hurry and it didn't work, didn't have the time to debug it yet... but i think the lay-out is ok.
if someone wants to throw this together before i have the time to debug mine, please do so!
thanks to Bioroids for the schem.
http://www.last.fm/user/birt/
zpyder
sweet, I'll definately try this one out sometime soon...
thanks!!!
zpyder
www.mattrabe.com/ultraterrestrial Ultraterrestrial - Just doing our little part to make new rock go where it should have gone in the late-90's, instead of the bullshit you hear on the radio today.
zpyder
Questions-
1) What the hell is up with that potentiometer?
2) Why do you space several resistors at only 2 holes ... ? with no spacing in between.  I see other ways to do this without having to place those resistors vertically...??
thanks,
zpyder
birt
the pot has two lugs (2 and 3) soldered together to the circuit and the other lug to ground.
i do place resistors vertically to keep lay-outs compact.
oh and i'd like to know what all of you think of the way i make perf lay-outs.. i mean the notation, colours, shapes...
thanks,
bert
zpyder
Quote from: birt on October 16, 2006, 01:43:52 PM
Okay gotcha...  I'd suggest noting this on the layout - it is not initially clear.  Somehow you need to indicate GR on lug 1 of that pot.  Also, you did not indicate if the pot was linear or log.
whatever floats your boat :)  In this case, I would have used R1 to get across the lead between IC2 pin9 & C2, and bring C1 and the IN terminal down toward the bottom right.  I don't know enough about twisted pairs, so I may be overlooking some utility there if you intended to twist IN with GR.  I'd really like to know if this is what you intended as twisting stuff is something I would really like to figure out before I build too many pedals without it.  It seems to me that by moving R1 to where I indicated, and using a top-left-to-bottom-right diagonal lead off of IC1 pin5, that R2 and R3 could be layed out to 4 spaces each.  That's just me I spose, but if you did intend to twist IN with GR, there is another ground terminal right where IN would end up if replaced how I suggested...
:: I find the writing hard to read in many cases - particularly the white fonts and the D1 over the diode, but in general the value labels are hard for me to read.  Maybe just some bold fonts...?
:: Although I can quickly figure it out by following the circuit, the "X" on the electro cap does not indicate anything to me.  Instead, I would indiate the negative side with a "-" symbol, since electros are marked on the negative side.
:: I like the use of red for traces/leads.  It makes them very easy to see through components, which is often an issue without other layout color templates.
:: Why not use white or some much lighter color for the background?  Would create more contrast.
:: Reading "GR" over the pink is exceedingly difficult.
cheers - to DIY!,
zpyder
birt
normally i don't use the white component values since i always have the schematic with me when i build a pedal. i never use the lay-out on its own (the same goes for other peoples lay-outs).
the X on the caps should actually be a + since a - gets lost in the lines of the traces and components. this si also clear when you have the schematic with you as you build it ;)
i seem to have enough contrast on my screen :s
i know, but i used it to have an easier job wiring the board. i know all pink are ground connections and all white are 9V. on a board with a lot of wires this makes things easier since i always start the wiring with ground and 9V
zpyder
Right on...
Yea, I kinda figured the "X" was a 45-degree-off "+", it's just not obvious.
Maybe a parts list below the schematic with the values for each component listed, rather than putting them right next to the component.
I too also always have the schematic right there when I build from a layout...
Did you intend to twist IN & GND?
zpyder
Austin73
interesting conversationn but does it actually work yet! I hope so as I really want this one!
Cheers
Aus
Bazz Fuss, Red LLama, Harmonic Jerkulator, LoFo MoFo, NPN Boost, Bronx Cheer, AB Box, Dual Loop, Crash Sync
birt
Quote from: Austin73 on October 16, 2006, 04:51:34 PM
Cheers
Aus
build it and you'll know ;)
oh and i didn't inted to twist in and ground, i've never tried that
Austin73
ok will order the chips next week.
what does everyone mean by twisting in and ground?
Aus
Gilles C
Instead of using a shielded wire for the input, you can twist the ground and the input wire together to help in reducing the noise picked-up by the input.
Gilles
bryantabuteau
hey, I read the MC14066B (4066) is a pin for pin replacement for the 4016.  I can get these locally, but as I'm unsure how the aliaser actually works, does it rely on the limitations of the 4016 or can I do a substitution...?
birt
my pedal works but there is a loud hum (louder than the guitar).
its a plain hum until the frequency knob is about a quarter up, then the effect kicks in and the hum is modulated.
with the frequency knob below that point there is also no signal coming trough.
birt
in the first lay-out R10 was connected to pin 3 of IC2 instead of the junction of C5 and C6. i corrected the lay-out and i hope there will be no problems anymore once i fix this in my pedal.
birt
i just changed it. now the frequency pot is fully functional and the hum is gone. but it's still self oscillating. or maybe thats just the modulated hum thats left?
birt
*BUMP*
i'm a bit lost with this one. i'm pretty sure the lay-out is correct altough the pedal still doens't work like it's supposed too.
help me out plz!
birt
i found out some weird stuff after replacing all the wiring and reheating every solderpoint.
the noise volume changes when i hold the board in different directions. also when i touch the junction of C7 to pin 5 and ground at the same time the noise goes away but the effect too and my guitar sounds a more like its bypassed. C7 as well as C6 make a lot of noise when i touch them.
there is also a little bit of this noise in bypass (from ground i guess) but only when the frequency pot is set to high resistance. in about one fourth of the pots taper it suddenly dissapears.
