Triangle Muff mods for Siamese Dream.....
Started by powerplayj, October 25, 2006, 10:34:35 PM
powerplayj
This topic has been revived lately but it seems the discussion always drift off into the ethics of the Creamy Dreamer and its owner.
I'm just curious what else I need to do with a Triangle Muff to get it into Siamese Dream territory.  I have seen mods to eliminate the emitter resistors for Q1-Q3 but, I was just curious if anyone had any definite values for the tone stack.  (I have seen suggestions by Yun as well as his suggested schem for the C.D.).  In the meantime, I'll try his suggestions but was curious if there are any other suggestions such as different trannies for the 2N5088s, etc.
Here is another good resource....
http://www.student.ru.nl/r.kerkhof/Taas/Mods/Big%20Muff.htm
Thanks,
Jason
builds completed: boutique fuzz, rangemaster, BSIAB2, PT-80, Tonepad wah, Ross Comp, Axis Fuzz, MOSFET boost, Thunderchief, Big Muff (triangle), Mr. EQ, Dr. Boogey,  Neovibe, Dist+, EA Tremelo, ADA Flanger, RM Octavia
next build(s): ???
Dragonfly
PM forum member "Yun"...he knows a ton about Big Muffs and mods for them...
also...using the "search" function for "creamy dreamer" should yield some results....
AC
Processaurus
You might try the Swollen Pickle values for the tonestack, it shifts the mid notch lower than the BMP, to about 700Hz, which may = a more 90s sound.  I believe the cap value changes were making the 10nF a 33nF, and the 3 or 4nF (can't remember, the smaller cap in the tonestack) a 10nF.
When I saw 'em in '95 they kinda sounded weak compared to their recordings,  I guess 40 tracks of guitar overdubs will tend to sound thicker than a lonely muff, no matter what mods you got going.  Its valiant to try, though.
amz-fx
Quote from: powerplayj on October 25, 2006, 10:34:35 PM
The mid-range mod came from my design at:
http://www.muzique.com/lab/tone3.htm
The Creamy Dreamer info came from the stuff I posted about the one I bought, disassembled, figured out how to get the heavy coating of epoxy off, and then traced...
Creamy epoxy - Creamy no epoxy
It would have been nice if he had given me a link at the bottom of that page....
regards, Jack
Bernardduur
You want one?
PM me the link and I will add it!
Am learning something new every day here
SquareLight | MySpace account
