Tremulus Bear build
Started by DryRoasted, November 13, 2006, 05:27:26 AM
DryRoasted
Morning all,
I'm currently building Steves wonderful Tremulus Bear, but I got two quick questions, The LDR that came with the kit has two short legs and two long legs, at the short leg end there is a white dot, do I take it that the DOT end is positive or vise-versa?  Secondly, on the instructions it lists R2, R3 and R 10 as 22K resistors, but a few lines down it again lists R10 as 3.3K (This is on page 8 of the build instructions), anyone tell me whch it should be?
Cheers
Jim
Sticking a tube into a tube screamer to get good sound is about like rubbing yourself all over the weight stacks at the gym to get stronger - R.G.
MartyMart
"Dot" should be the positive side of the LED, other long wires are LDR
MM.
DryRoasted
smallbearelec
Quote from: DryRoasted on November 13, 2006, 05:27:26 AM
Morning all,
On the instructions it lists R2, R3 and R 10 as 22K resistors, but a few lines down it again lists R10 as 3.3K
Thank you for picking this up! R10 is 22K. I will correct the list in a few minutes.
MartyMart
Jim , my bad .... Dot could be Cathode !
Anode (+) are usually slightly thicker lead than the cathode
I would check the data sheet to be sure ...
EG : http://www.silonex.com/datasheets/specs/images/pdf/103708.pdf
MM.
  I used to have such troubles with this, lines anodes and cathodes confused me.
  I grabbed an LED, set the DMM to diode checking, then got the LED in the vactrol to mimic the LED readings.
DryRoasted
Quote from: petemoore on November 13, 2006, 10:37:52 AM
Lol, sorry? ;)
As for the spec sheet, it doesnt have any marking at all other than a white dot
