SOT: Naive question about a simple amp idea
Started by brett, November 13, 2006, 10:15:03 PM
brett
Hi
Looking at simple schematics for amps, I found this for a Class B amp:
I don't look at many amp schematics, but hadn't seen anything like this before.  To use an op-amp to switch the offset between +0.7V and -0.7V seems a cool idea.  But is there any problem with it?
My idea for a simple guitar amp is to use:
one (half) TL072 op-amp or similar as a pre-amp (voltage gain up to about 200)
a 24V, 1A wall-wart for a +/- 12V pwer supply,
the other (half TL072) op-amp as the offset switch,
a pair of 2N3055/2N2955 transistors on an appropriate heatsink.
I anticipate feeding the power section up to 8V RMS and drawing up to 1 amp, for 8W output.  That seems quite good for such a simple amp and power supply.
Any advice will be greatly appreciated.
cheers
Brett Robinson
Joe
It will work if the opamp can supply enough drive current for the output transistors. 3055/2955's are probably overkill (try TIP31/32). Crossover distortion in this thing is dependent on the slew-rate of the opamp. It should be more noticeable at lower volumes, where the distortion takes up a greater percentage of the output signal.
brett
Hi
I'm kinda surprised but  :icon_smile: that this will work.
With a slew rate of 16 V/uS, the response of the TL072 should be quick enough to switch the two transistors (ie in less than 1 uS).  But it might overshoot a bit, I suppose.
Thanks for the hint about the 2N devices being overkill (and low hFE).  With a hFE of 100 at 1 amp, a TIP31 only needs about 10mA.  I'm figuring that a TL072 can produce that OK (10mA from about 10V is equivalent to about a 1k ohm load).
Any advice about how sensitive this will be to power supply ripple?  I was thinking of 2 x 2200uF caps on each rail, based on the rule-of-thumb that says you need a minimum of 2200uF per 1 A.
Thanks.
Brett Robinson
gez
A (suitable) resistor from the output of the opamp to each base of the tranistors should make it more stable/bias better.   I've seen what I just described on a schematic for a headphone amp that's on the net somewhere.  If I have some time later today I'll try and find it/link to it.
DDD
Adding single 100-500 kOhm resistor from bases to emitter will make the amp much more stable with "more headroom" from the point of view of symmetrical distortion.
gez
#5
Couldn't find the schematic, but this page has some useful stuff under 'Class B and AB Symmetric Emitter Followers' (half way down page):
http://www.headwize.com/projects/opamp_prj.htm
