|AMPAGE| |GEOFEX| |AMZ|
May 18, 2013, 11:14:02 PM
890658 Posts in 97537 Topics by 28664 Members
Latest Member: jetmarshall
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  Linear Power Boost 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: [1] Go Down Print
Author Topic: Linear Power Boost  (Read 285 times)
YouAre
Linear Power Boost
« on: December 18, 2006, 02:02:20 AM »
Can anyone give me the lowdown on the old/new linear powerboost? BYOC has a kit which includes the LPB, and I figure'd I'd by a PCB and build all three boosts on it instead of just the amz mosfet boost like i had planned.
Pros/cons?
Sound description?
Thanks,
Murad
Logged
d95err
Re: Linear Power Boost
« Reply #1 on: December 18, 2006, 02:23:50 AM »
LPB - a little distortion, but fairly clean
Rangemaster - more like a low-gain overdrive if you have hot pickups. Lots of Germanium mojo...
MOSFET - very transparent, too transparent sometimes.
All three boosters work well for pushing a tube amp into more distortion. For "solo" boost, the MOSFET boost is probably the best choice.
If you are using a solid state amp, the Rangemaster is completely useless.
Logged
YouAre
« Reply #2 on: December 18, 2006, 02:31:39 AM »
the pickups i'm using are tone anderson h3+/h1- in my les paul (really hot), and GFS mean 90's in my epi hollowbody. those are goin into a fender prosonic.
thanks for your post. I think it'd be a good build. would you say the the LPB could be like a cross between the tone coloring of the rangemaster, and the transparency of the mosfet?
Would any of these sound good boosting a BSIAB II?
Logged
d95err
« Reply #3 on: December 18, 2006, 03:41:58 AM »
In general boosters work well for boosting overdrives or distortions. It's when you try to boost a clean solid state amp that it usually sounds bad.
The BSIAB is essentially one booster boosting another, but I guess adding yet another booster infront couldn't hurt...   Wink
Logged
Pages: [1] Go Up Print
« previous next »
Jump to:
