Wtf? Look at these Electrolytics I just got.
Started by MikeH, December 21, 2006, 09:24:49 AM
MikeH
Where's the negative side?  They have a "negavitve stripe" on them, but it doesn't indicate any direction.  It looks like this is maybe the outer-wrap for a radial cap?  All of the other electrolytics I have,l have the positive side where the groove is, is that always the case?  Is there any other way to tell which side is negative?
darron
yeah. that's weird, and there's a bulb at one end like a radial one. since there doesn't seem to be ANYTHING else to go by, i'd GUESS that the left side is negative?
i don't have an answer. i just wanted to confirm that it looks weird! :P
KerryF
Hmmm most axials have arrows.  Use a multimeter.  Im pretty sure the bulb side is negative (-)
I have a number of electrolytics that I bought surpluis over the years, and they sit unused in my bin because I have no way of figuring out which side is negative/positive.  For the very same reasons: the package is VERY ambiguous.
So, how DO you identify polarity with a meter...or any other method?
birt
on every axial electrolytic i have the + is the side where the body has that curve
http://www.last.fm/user/birt/
Paul Marossy
Quoteon every axial electrolytic i have the + is the side where the body has that curve
+1
amz-fx
The aluminum can is almost always the negative side.  This is probably the end opposite the groove.
regards, Jack
MikeH
And of course I picked these up to work on a Compressor, which uses about a hundred of these, so it's not like I can just solder one in and see if it works or blows up or whatever.  That aside, the electrolytics I have that actually have the arrow, all show the groove side as positive and the bulb side as negative, so I think it's a safe assumption.
MartyMart
Tubebass
Quote from: amz-fx on December 21, 2006, 10:27:47 AM
regards, Jack
And isn't the + side usually a black rubber plug?
More dynamics????? I'm playing as loud as I can!
jaytee
Just confirming what someone else said. The end with the waist and rubber plug will be positive, the other end connected to the can will be negative. Looks like they ran out of sleeving for axial caps.  ;D
Alex C
I just got a few like this from Mouser the other day.
I'm glad this was posted, I wouldn't have known what to do with 'em.
analogguru
Quote....I picked these up to work on a Compressor, which uses about a hundred of these....
can you post a schematic of this compressor ?
I guarantee you, after assembling 50 pcs you should have learnt to know the correct orientation.
Thats the positive on European schematic symbols: for an elko - is black, an + is empty (white), like the waist of the elko.
analogguru
Fuzzy-Train
I've used a couple of those for a FF, and my octavia... the negative side is the side with the bulb.... that's the side where all my arrows are pointing so...
THERE IS NO SIG.
The user formerly known as NoNothing.
Stuff I built!
http://s174.photobucket.com/albums/w106/Cpt_sergeant/?start=allRandom
