Tremulus lune, mirrored PCB??
Started by snoof, January 09, 2007, 09:45:17 PM
snoof
I wish I would have found out that you can't transfer the trem lune PCB from commonsound to a board without flipping it before I ethed and drilled it :icon_mad:.  It's backwards/mirrored now.  Can it be salvaged??  The opamp pinouts are wrong...
stobiepole
You should be able to install the IC on the 'wrong' side of the PCB. That should work...
Chris
theundeadelvis
That's what I did on my first tremelus lune build.
snoof
#3
kudos to commonsound for the project, but I think they should say something on the website about this :icon_question:  I'll see if I can't install the amps "wrong way round".  I'll guess I'll have to use jumpers of some kind.
Barcode80
no jumpers needed, just bend and solder the legs of a socket to the spot traces for the IC, then plug 'er in
