Stacked Delays
Started by erick4x4, January 18, 2007, 01:28:31 PM
erick4x4
Ok, so while I am still hoping for Line6 or Boss to do this . . .
I currently use a Echo Park->DD-20->Verbzilla to get some really cool spacey sounds. Usually a Sweep Echo or Auto Swell tapped at 4ths, to the dd-20 digital with dotted eights into a really big verb.
Does anyone know of delay/reverb pedal or unit that can do delay and reverb, let you stack them (2 delays and reverb same patch), small enough footpedal to fit on a pedal board, with tap tempo, and NOT SUCK?
I love having the 3, I use a bypass loop to get it like a patch, but would be awesome to have presets and only tap tempo one time. I know I don't have any skills with DSP's and doubt I could build anything like this, so I thought maybe someones knows of something commercial, or something someone else has designed that I could work with.
Anything do this?
Seljer
I don't think there are any delay pedals that can do all that, you'd probably have to go into the fancier rack delays and other rack effects if you want tons of layered effects with easily configureable patches
Seljer
