TC Electronic Classic XII Phaser Pedal notch/peak function switch?
Started by markphaser, February 18, 2007, 11:39:15 PM
markphaser
The TC Electronic Classic XII Phaser Pedal has a notch/peak function switch
What does this notch / peak function switch do?
Quite probably it inverts the feedback signal or inverts the overall phase-shift signal at the point where it gets mixed with the nonphase-shifted signal.  IN the one setting the phase shifted portion will produce notches.  IN the other it gets added to the dry signal to produce peaks.
That is my guess.
markphaser
Thanks alot mark hammer for the help
1.) IN the one setting the phase shifted portion will produce notches.
Do u mean "Not mixing with the dry signal" just only the phase wet signal? will give u just notches
2.) IN the other it gets added to the dry signal to produce peaks
No.  I mean that when you mix the dry/clean and phase-shifted signals together in-phase, you get a different sound than when you mix them together out of phase.  Phase-shifted only without clean will produce vibrato.
