The TrotskyDrive
Started by dano12, March 03, 2007, 07:28:43 PM
axeman010
Hi Dano
Please accept this as a question and not a criticism but is that way of biasing a transistor a little unstable? (Susceptible to variations in temperature and supply voltage)
I am trying to get in to designing with various transistor types at the moment and understanding biasing etc. I think I'm right in saying that this is a Collector Feedback Bias Circuit. I'm a little curious why you choose this method over the voltage divider bias or auto biasing method which seems to be more widely used for pre-amps, boosters etc.
Any insight that you could give in to how the resistor values were calculated would also be much appreciated.
Clive.
Hanging on in quiet desperation is the english way
DWBH
Instead of those 1N914 and 1N34A, can I use any other diodes?
I was thinking of a 1N4148 to substitute the 1N914 and 1N60 for the 1N34A, I don't know....
[noob mode on]What are these diodes there anyway? Clipping? [noob mode off]
dano12
Quote from: axeman010 on May 16, 2007, 05:22:51 AM
Hi Dano
Clive.
Hey Clive, no worries on the questions. The Trotsky drive started out on the breadboard with fixed value resistors to adjust gain.
I tried the traditional bias route, which is usually the better approach, and then for fun, stuck the bias pot up top instead. To my ears, the pot rotation with the second approach was more interesting both from a design approach and sound-wise. The key drawbacks in my approach are pot noise (DC crackle) and more difficulty in finding the sweetspot.
The values for resistors were breadboard trial and error: select a range of fixed values that gave me the gain window I wanted and then choosing the pot value to cover that range.
dano12
Quote from: DWBH on May 16, 2007, 11:45:04 AM
You can use just about any type of diodes for clipping: silicon, germaniums, LEDs, MOSFETs, et. al.
I chose germaniums because they clip at a lower forward voltage and the Trotsky, with its single low-gain tranny, doesn't push a huge amount of signal through the diodes.
Minion
I built a Trotsky last night and I used an Old 2SC968 Germanium Metal Can (T0-52) and ran it off of a 15v Supply and it sounds Pretty Good....I used one 4148 diode and some Mystery Germanium Diode for the Clipping ....I am very happy with it , It isn"t over the Top but Gives a Nice AC/DC type overdrive, good for R&R and Blues type music.......
Go to bed with itchy Bum , wake up with stinky finger !!
ambulancevoice
1n4148 is pretty much the same as 1n914
1n60 is the same with 1n34a
OMG! I just breadboarded this but using positive earth with a Ge PNP SFT353 and two germanium diodes - I can't believe it sounds so good - there's next to no components!
Amazing!
Deserves a bump for n00bs!
bamera
I built the trotskey a few months ago and I love it. Dano´s classy and very organized project pdf made me want to build it... :icon_biggrin:
cheeb
I built a lightly modified one for a friend and he plays gigs with it regularly. He is in love with it and now there are four people in line that want one, and he's having me make another with a clean blend. It's a hit around here.
ayayay!
Yeah, if people would just get past the crackle (which is hardly noticeable on mine,) they would see that it's really a great pedal.  I removed my TS5 on my board in favor of this, for boosting my overdrives & distortions.  Not that there's anything wrong with the TS5, but the Trotsky Drive just works better for me when boosting.
The people who work for a living are now outnumbered by those who vote for a living.
kurtlives
I like mine...
Badass little box.
My DIY site:
www.pdfelectronics.com
morpha2
Same here. Mine has earned a spot on the chain for sure.
The Iron Chef
The Trotsky Drive was the first pedal that I built to completion.
QuoteDano´s classy and very organized project pdf made me want to build it
I built it to spec except for the transistor. no old soviet stuff here so i I first used a 2n2222 then changed to a 2n3904 for a little more gain. sounds  fine, nothing over the top, as advertised.  Thanks for sharing.  My Trotsky, below.
-Keith
I build stuff everyday.
ayayay!
Ahh, another "built into the lid" pedal.  Don't see those often but I like the looks of them.  Nice "Russian" text as well!  Thanks for sharing!
FisTheGoon
Seem a lot have build this pedal.Anyone can upload some sample from TrotskyDrive?Would love to heard some of it. ;D
danielzink
Quote from: FisTheGoon on October 04, 2008, 12:57:34 PM
Videos and sound samples here:
http://www.myspace.com/nmgeffects
ehofherr
Quote from: danielzink on October 04, 2008, 03:01:01 PM
Excellent demo.  The sound is very nice...think I might have to give it a try myself!
Need help with woodworking?  Just ask.
ConanB
I've had this FX together for a little while now but I need to get off my arse and finish off it's box >.<
Great sound.
DWBH
Just boxed this baby.
I have TONS of output. I put it in a A box, so I had to ditch the volume knob.
The thing is, the gain knob doesn't work. I hear the crackle, but there's no difference in gain level.
It gives me a rather clean boost, a big one, that's for sure, but when using it with dirt boxes it fattens them up, into an creamy almost-fuzz  :icon_twisted: :icon_twisted:
Oh, and I used LEDs instead of the 'normal' diodes.
Quote from: DWBH on November 05, 2008, 03:59:29 PM
You need to use normal diodes for this circuit to clip, as the LEDs clip at too high a voltage. Try a few different ones. The gain control should also then start to function.  ;)
