Tremulus Lune (Fuzz Central Layout) Wiring help?
Started by calculating_infinity, April 09, 2007, 04:58:03 PM
Hey, so I populated and wired my trem lune up last night.  I am having problems figuring out if the LED goes to "Switch for LED on/off" and "LED +".  Does this mean I don't wire the LED up to the Bypass switch?  Also the layout states Fine and Speed only have connections to lug 2.  Where do the other connections go? (lug1 and lug3).  I had it wired "switch for led on/off" to my bypass switch and LED + to the LED.  When I tried it, it would boost the hell out of my signal when bypassed and soft when it was engaged (could be backwards).  So yeah the LED and Fine and Speed pots are what I need help with.  Thanks!
Here are the links to the Schem and layout:
http://fuzzcentral.ssguitar.com/tremulus.php
http://fuzzcentral.ssguitar.com/tremulus/tremuluslayout.gif
-Jonathan
Doh, thanks leon.  I knew I should have checked the 4ms site.  I will try and wire it up according to this diagram when I go home from work.  I will hopefully be able to get it to work then.  Thanks again!
-Jonathan
