Small Stone switch POPPING!!!
Started by miketbass, April 27, 2007, 07:41:14 PM
miketbass
Alright, this is getting frustrating. I have an issue J Small Stone that I made true bypass and fixed the volume drop on. The switch pop was unbearable so I used the alternate stompswitch wiring I found on AnalogMans website (the one that grounds out the board). This cut down the pop but it's still very audible. I tried 1 meg pulldown resistors on both the input and outputs to no avail. I'm very disappointed right now...the AMZ Mosfet boost I built pops very badly too and I've only been able to tame it down to "nearly-useable". Anyone with any ideas?
Rafa
how about electronic switching? There are some good Ics for that.
Cheers
Rafa
fixr1984
Are you using an LED. That can cause popping when you switch.
Here is a fix for that.
Gus
You did not post what brand etc switch.  Sometimes the switch caiuses the pop and circuit is good.
miketbass
Sorry I was kind of vague on my setup in the initial post. No LED. The switch is a DPDT Carling, the good ol' standard. I'll look into the electronic switching thing, I haven't researched that one bit.....
