STEBY boost: very simple PNP boost
Started by Steben, May 07, 2007, 06:33:55 AM
Steben
Very simple boost, to use with ANY PNP, which means germanium-friendly.
Combination of bias and input control. Since PNP biases to negative voltage, a simple "volume" control does the trick.
For some grainy, wooly boost. Very useful IMHO in front of (too) low gain fuzz projects.
Marcos - Munky
Wow, it's very simple. Soundclips???
Barcode80
nice! finally a use for all those 2n3906's i have laying around. i never really build pnp much, as it conflicts with my pedal power and i don't use batteries, but this would be good for boosters for some friends!
sfx1999
That's actually a negative ground circuit, so you could use it.
Meanderthal
QuoteANY PNP, which means germanium-friendly
Quotenegative ground circuit,
Ok, now I have a use for those pesky PNP Germaniums! Nice little thingy! 8)
sfx1999
Hey if you want to build negative friendly positive ground circuit, you can use a circuit like this: http://www.aaroncake.net/circuits/vinvertr.asp
I would recommend the use of schottky diodes in there.
You could also use the +9/-9 supply from geo and just not use the +9.
