EA Tremolo layout by Paul Marossy distorting
Started by xnery, May 13, 2007, 10:21:55 PM
xnery
Hello everyone.
I have been working with tremolos lately. I originally built the EA Tremolo according to the circuit and layout at general guitar gadgets, but got tons of distortion. I then stumbled accross Paul Marossy's layout at http://www.diyguitarist.com/PDF_Files/EA-TremoloPCB.pdf Paul's worked immediately, and only distorts if you have humbuckers at full volume and strum full chords rather hard. Would there be a way to reduce the input a little? I tried moving the volume pot to the front of the circuit, but it seemed to buzz a lot. I was just runing the input to the pot, then the pot to the circuit board. I would greatly appreciate any advice, this tremolo sounds great otherwise, and it was so simple.
Threefish
I had the same problem with my EA trem distorting, and there is a easy fix. Have a read of my build report on a modified (ROG) EA Trem with the ROG layout, with the gain control at the input.
http://www.diystompboxes.com/smfforum/index.php?topic=45546.0
I didn't get any buzzing (you've probably got a dicky connection somewhere). It should solve your problem.
It's a beautiful Trem. I love mine.  :icon_biggrin:
Reid.
"Why can't I do it like that?"
xnery
It looks like I have to put the volume control after the input capacitor. When I tried it, I had place it before the cap. I suppose that would make some difference.
Threefish
I think Pot Before Input Cap=DC Across Pot = Crackle, like the Crackle Ok? knob on the ZVex SHO. There's a couple of threads in the forum about it. Haven't seen the SHO schem, but I understand that's why that happens.
markm
I've never had a distortion problem with mine, although I have read more than one thread concerning this.  ???
xnery
I tried runing the volume control right after the input cap, but it still gives me a lot of crackle. My layout and parts aren't the stock ROG pedal, so I'm not sure exactly what to do. Could someone please glance at http://www.diyguitarist.com/PDF_Files/EA-TremoloPCB.pdf and give me another hint  ???
Thanks ;)
Paul Marossy
I never had an issue with distortion, but as has been mentioned, some people do. It is a preamp, too, after all.
You could always use a fixed voltage divider to keep the signal level at a fixed setting.
xnery
#7
How would I do that? It's new to me. Sorry to be such a noob  ??? Are you THE Paul Marossy? If so, you're pics and site have been a great inspiration for me.
Paul Marossy
QuoteAre you THE Paul Marossy? If so, you're pics and site have been a great inspiration for me.
Why, yes, it is. Glad I could be of some use to you there.
QuoteHow would I do that? It's new to me. Sorry to be such a noob
I'm not quite sure how to explain a voltage divider with just words. It's basically taking a certain value resistor in series with the output and using a resistor of the same value to ground at the inlet to the resistor in series to halve the voltage. There's numerous threads discussing voltage dividers here at the forum.
A simpler way for you to do it is to use a trimpot wired as a volume control in a set it and forget mode. A 100K trimpot should work OK.
xnery
Where on the layout would I put the prongs of the trimmer? I'm so close to figuring this out...
markm
If you're putting in a trimmer to substitute the volume control, maybe it would help to take a look at my build?
Paul Marossy
QuoteWhere on the layout would I put the prongs of the trimmer? I'm so close to figuring this out...
I would probably place it after the preamp. Pin 1 would be from the output of the preamp section, Pin 2 would go to the next stage of the circuit and Pin 3 would go to ground.
xnery
I'm guessing that the preamp section includes the first 2n3904 that the signal passes through. I would then place the trimpot between the Emitter of the 2n3904 and the 180 resistor. Does that sound right?
Paul Marossy
You know, I think I would actually put a 1K trimpot wired as a variable resistor in place of the 180 ohm resistor on the emitter of the 2N3904 on the input. Then you can adjust it for a little less gain.
xnery
Does replacing the 180 ohm resister with a higher value reduce the gain of the 2n3904? Or is a lower value necessary?
Paul Marossy
QuoteDoes replacing the 180 ohm resister with a higher value reduce the gain of the 2n3904? Or is a lower value necessary?
A higher value will reduce it.
